Yep so if it is not deep enough (My din space is about 180mmx180mm and the board I want to use is about 170mmx170mm)
Do something like this and lift the back up:
Scion xB '06, in-dash Atom 330, Lilliput 889GL; details, pictures, links. Index: pg 1
By raising it you give yourself extra space for cables at the back.
For example if you raise it 90mm I have 110mm or so to work with the depth of the board is now only 145mm if my trig is correct.
Alternatively put it up on an angle like that and then have the cables come out to the side if you have more room. Then you can still mount drives and
power supplies above and below it
But feel free to go under the seat, that is just not an option for me as I have a four wheel drive and I am sure that one day my computer will get wet if I keep it there!
