Page 6 of 14 FirstFirst 1234567891011121314 LastLast
Results 51 to 60 of 135
Thread: Newbie here
  1. #51
    May 2010
    Australia
    Lol will get OldSpark to check me but yeah they perform the same job of blowing if there is a short circuit. They perform a little differently if using for overload protection I believe but not sure on the specifics of that.
    I don't really care what most of it looks like as it will be hidden away, just needs to work and not fail in the mud or dust or vibrations.
  2. #52
    Jul 2010
    yeah.. i was going to hide most of it.. but then decided to have the fuse holders/large cables visible for some 'bling'
  3. #53
    May 2010
    Australia
    Go have a look in autobarn then. Most of the connectors and things I saw in there in their audio section looked flash. Probably more expensive..
  4. #54
    Jul 2010
    yeah.. going there tomorrow after work..
  5. #55
    Jul 2010
    ok, even autobarn didn't have what i wanted, so have gone for a single fuse up front, through to a dist. block in boot, through to 2 single fuses in boot, through to PC and AMP.
    BUT, another probably silly question, but how do you guy actually connect the 4ga wire to the M2-ATX? all the spade connectors that would fit it, are way too small for 4ga wire.. ??
    I did a search here but i can't see anyone actually saying HOW they do it..
    Or do i just trim the wire until it does fit and then heatshrink it etc?
    Cheers
  6. #56
    May 2010
    Australia
    Yeah that is an issue I am going to ask OldSpark about.. I found some huge lug terminals but that doesn't really help get to the psu..
    Unless you put a bolt somewhere as a distribution point then run a smaller cable off it for a short run..
  7. #57
    Jul 2010
    Well i could have got a distribution block that has a large output (4ga), and a smaller output (8ga), but someone here said i should just use 4ga all the way, so i got one that has 2x 4ga outputs..
    hrmm
  8. #58
    May 2010
    Australia
    Well it would be better yes as then you don't burn out the smaller section when the psu pulls a peak amount but they don't tend to make things big enough to go on the wire and small enough for the device..
    Need something to step it down.. besides if you are like me the only reason you have it so thick is for the distance the current capacity.
  9. #59
    Jul 2010
    hrmm.. from the distribution block to the CarPC is only going to be maybe 1m or so... maybe about the same to the AMP as well..
    But obviously from battery to Dist. is going to be longer.. maybe about 5m
    Looking around it seems i'm not the only one with the same question...
  10. #60
    May 2010
    Australia
    Yep and if you are running earth back like I am that's a 10m loop so you need thick wires so you don't loose too much voltage over the distance.
  1. Newbie, but not so newbie
    By comptech_69 in forum Newbie
    Last Post: 12-06-2006, 08:33 AM
  2. Links to FAQS in the newbie section!?
    By lostreception in forum Mp3car Forum Suggestions/Comments
    Last Post: 09-20-2005, 05:33 PM
  3. help a computer BUILDING newbie out....
    By jusatry in forum General Hardware Discussion
    Last Post: 02-11-2004, 04:39 PM
