Page 7 of 14 FirstFirst 1234567891011121314 LastLast
Results 61 to 70 of 135
Thread: Newbie here
  1. #61
    Jul 2010
    I dont' think i'll be running earth back to battery, i'll just be finding a likely spot to add it in..
    My car has something like 12 ground spots standard already..
  2. #62
    May 2010
    Australia
    Yep, mine being in my canopy doesn't have any reliable grounds. Combine that with vibrations and what not it is safest to have a dedicated earth saves a lot of stuffing around trying to figure out why stuff is failing later.
  3. #63
    Jul 2010
    Well test built the PC and installed embedded win 7 standard onto it today..
    http://i52.tinypic.com/281snzt.jpg
    everything seems ok so far
  4. #64
    Jul 2010
    Ok i'm looking at trying these drivers to get 800x480 out of the PC,
    http://www.cartft.com/support/drivers/Intel_800x480
    but does anyone know if the monitor supports 70hz?
    http://store.mp3car.com/ProductDetai...ctCode=MON-016
    I can't find much info on it...
    Cheers
  5. #65
    May 2010
    Australia
    Most monitors are 60 aren't they..?
    It didn't have 800x480 as an option when you connect it?
    I suggested something in this thread today as they were having trouble too mut your solution might be better.. no idea..
    "Transflective" LCD panel with res touch+controler for $101+$36 S+H
  6. #66
    Jul 2010
    Quote Originally Posted by stretch4x4 View Post
    I can only go down to 800x600 with standard drivers..
    I found this: http://software.intel.com/en-us/arti...ntel-graphics/
    which could help if i could make any sense of it ... similar to what you posted i think, but more complicated
  7. #67
    May 2010
    Australia
    That does look pretty good, think I could follow it if I was trying to do it.
    Was just asking as generally they wont show all the possible resolutions only the ones the monitor tells the computer it can handle.
  8. #68
    Jul 2010
    I think i might just stick with 800x600 the Lilliput does display it, and it doesn't look bad or anything.. but i guess native res would probably be better..
    though Intel does state it supports custom resolutions in control panel.. but i can't see a way to set any
    New Control Panel - New look and feel, easier to use, with custom resolution settings.
  9. #69
    May 2010
    Australia
    Yeah sure would..
    Any bit in particular you are having trouble with?
  10. #70
    Jul 2010
    Everything lol.. but i'm learning..
    I don't think it's showing the native res for the lilliput, because the lilliput isn't plug & play? it just shows as 'generic non P&P monitor'
    A few more questions though..
    What do most people use as a mic?
    What about bluetooth? just any old BT dongle?
    How do i incorporate that into everything else including the mobile phone (including mute) etc?
    Now that i'm getting into this, i'm starting to think about what else i can do lol...
  1. Newbie, but not so newbie
    By comptech_69 in forum Newbie
    Last Post: 12-06-2006, 07:33 AM
  2. Links to FAQS in the newbie section!?
    By lostreception in forum Mp3car Forum Suggestions/Comments
    Last Post: 09-20-2005, 04:33 PM
  3. help a computer BUILDING newbie out....
    By jusatry in forum General Hardware Discussion
    Last Post: 02-11-2004, 03:39 PM
