Results 1 to 3 of 3
Thread: Testing Wiring and screen question
    Apr 2010
    Im using an Acer Aspire Revo with a carnetix P1900 and have it wire to the computer but was wondering if there is a way to test the power before doing all the wiring in the car. Would like to make sure I get it right.
    On another note I have one of these but it doesnt work as the only monitor so was wondering if there is a way to convert it to a vga input and use it. If not then suggestions on a non touchscreen 6.5-7 inch monitor for relatively cheap to use. Thanks
    Elsewhere
    There is a writeup on this in the FAQs. It outlines how to test your setup using an ATX power supply on your workbench.
    How about the Wiki?
    Jun 2008
    Seattle, WA
    Quote Originally Posted by NightJumper View Post
    Your question isn't very clear. What is "these"? Is it one of those USB monitors? If so, I've read on here that they do work as the only monitor, but only after Windows starts up. You don't see the bootup screen before Windows has started. You'll probably have to adjust the Windows display settings to make it the primary monitor. You may need to plug in another monitor temporarily to make the change.
  1. 2007 Mazda 3 Dash Screen looks OEM
    By Splash-X in forum Show off your project
    Last Post: 05-04-2009, 06:29 PM
  2. Wiring question
    By Fal1acy in forum Newbie
    Last Post: 11-20-2008, 04:12 AM
  3. Help with wiring screen + inverter for pc
    By stylz in forum General MP3Car Discussion
    Last Post: 11-19-2008, 12:25 AM
  4. Wiring in dash screen: How-to...
    By marzman in forum LCD/Display
    Last Post: 05-29-2005, 08:38 PM
