Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Reverse Wire and Rearview Camera
  1. #21
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    the blue wire should be for power antenna, from my china model manual SNO
  2. #22
    Aug 2010
    Blue wire usually is. My blue reverse wire has a "BACK SW" label attached to it but you are right, blue usually is antenna.
    From other forums I have read nowadays they use the power antenna wire to power an extra amp. Most aftermarket units like mine have a wire for the amp but without that and since most people don't have power antennas anymore, the blue antenna wire has been known to power an extra amp. So I've read.
  3. #23
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    I'm assuming the blue wire is from your monitor... If so, I can't see any reason why you would attach it to the antenna. "BACK SW" most likely means "backup switch" (ie: figure out when to switch to the backup input). Maybe I'm missing something...
  4. #24
    Aug 2006
    PA
    Hmmm... Just noted the pdf file. Blue/Black (ie: a wire with colored strips, blue & black) is the antenna control wire. The Blue wire is as I described. If you look at the picture, the blue wire is connected to the "reverse lamp".
  5. #25
    Jan 2008
    careful , the power antenna wire will only have +12v when you are playing the radio, it will not work with any other funtions (at least that is how most radio s are setup)
  6. #26
    Aug 2010
    I discovered going thru one of the many menus that I have the option to activate or not activate the brake AND reverse systems. So grounding out the brake line technically didn't matter cause both were set to NO anyway.
  1. 1994 Peugeot 106 XS beeing upgraded just a bit
    By boelle in forum Show off your project
    Last Post: 10-16-2010, 02:41 PM
  2. How to simulate "Reverse" on workbench
    By JasonMK in forum General Hardware Discussion
    Last Post: 09-26-2009, 08:00 PM
  3. Wiring backup/Rearview camera -- can engine crank damage?!
    By justintime in forum General Hardware Discussion
    Last Post: 03-03-2008, 04:55 AM
  4. Rearview switching for a Xenarc?
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 07-05-2006, 02:47 PM
