Results 1 to 10 of 14
Thread: Need to find 12v (ACC) for 2010 Ford Escape
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    So, I am taking my carputer out of my 2007 Saturn VUE and installing it into my 2010 Ford Escape and I'm feeling like a total noob because I can not find any 12v switched wires. I bought and aftermarket wiring harness to make the speaker connections simple, but where there is suppose to be the ACC wire the Ford stock hu adapter has no wire, so the ACC wire on the metra harness goes to nothing. I have used my multimeter and tried every wire I can find and all I can find are 2-3v or a bunch of constants. If it were the other way around I'd be find (just run a constant directly to the battery), but how do I find 12v swicthed up by the drivers seat?
    _______________________________________________
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
    Newbie bakin113's Avatar
    Sep 2008
    Murrieta, California, United States
    This was a pain on my latest project. I put an older pioneer touchscreen in my girlfriends 2008 escape. There is no longer a switched +12v going to the stock radio. There is a fuse box on the passenger side by your feet that has wires going in and out. The wire I ended up using was yellow I believe and went up out of one of the wiring harness. Sorry I don't have any pics, I didn't have my camera when I installed it.
    Hardware: Two Diamond Audio D3 10" subs, 7" Lilliput eby701, 2.7Ghz AMD 45w Sempron, Gigabyte mobo, 512MB nVidia 9800, 1GB RAM, 500 GB, M4ATX
    Software: OpenMobile
    My First Build
    Jun 2007
    Annapolis, MD
    Quote Originally Posted by bakin113 View Post
    Thanks for the quick tip. So, then how did you "patch" into that wire? Did you solder, splice it or something else? I don't want to hack up the factory parts, but I also want to make sure the wire is safe and secure.
    Jan 2008
    the easiest way is to use a "add-a-fuse"
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Jun 2007
    Annapolis, MD
    Quote Originally Posted by soundman98 View Post
    Never heard of it before, so do I connect my wire to the "add-a-fuse" and then plug it into the fuse box where the fuse would be for a 12v switched line? Will that make the line turn on and off with the ACC?
    Sep 2008
    No i used a wire tap to the wire and used a little electrical tape to be safe... that area is tight though.
    It will send the same voltage through that wire. Check where the wire goes in to each of those harnesses and check which give you 12 volts when the key is in the ACC and check it again when the key is off.
    My First Build
    FLAC SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    for fuses i use the same scotch-lok technology they work great
    SNO
    Jan 2008
    Quote Originally Posted by SNOtwistR View Post
    SNO
    i have had long term reliability issues with IDC(insulation displacement connector)'s like these before, and would not recommend them for anything more then temporary wiring-- these can also affect the original wires corrosion resistance due to their design, which can also cause issues down the road...
    Quote Originally Posted by JasonMK View Post
    exactly-- just probe your fuse fusebox for a fuse that gets switched power, and then "add-a-fuse"! then the wire coming off of it could be used as the acc line for whatever devices you need it for.
    HID retro--100%
    Nov 2009
    Keswick,On Canada
    if you have probs with corrosion you are using the connectors for something they were not designed for. 3m makes water-tight scotch-loks for exterior use but never these type for sure even with super 33+. for interior use they are perfectly fine and have been around for 20-30 odd years and a little dab of no-ox if worried about metal differences
    Jan 2008
    being that they do cut some strands, i have also had issues with wires falling apart because of the connectors...
    overall, i just think that there are much better ways of connecting wires that don't affect the strength, or other parts of the wire..
    HID retro--100%
  1. FS: Ford Bolt In Xenarc 7" LCD Touchscreen
    By blk02si in forum Classifieds
    Last Post: 02-24-2009, 01:40 PM
  2. AOpenPC - Find 12V Rails?
    By PatInTheHat in forum Power Supplies
    Last Post: 07-31-2007, 03:59 PM
  3. cant find 12v dc-dc plans :(
    By djmickyg in forum Power Supplies
    Last Post: 06-21-2004, 03:44 AM
  4. Need to find acc wire that stays alive during crank.
    By Bobby Digital in forum Power Supplies
    Last Post: 02-05-2004, 05:42 PM
  5. Replies: 5
    Last Post: 07-12-2003, 01:43 AM
Tags for this Thread
