Results 1 to 10 of 10
Thread: windows xp not installing or booting
    Aug 2010
    hello
    im building my first carputer but not my first computer, I installed everything correctly but when i try to install windows xp it either says missing file or dosent load i tried installing xp through another computer on the same hard drive and it loads fine but when i try it on my carputer it crashes and gives me the bluescreen the error was (pci.sys) or something like that ,I tried several copies of windows xp and all with the same problem,then i gave openice linux a try and it worked fine but i would like to use windows xp .
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Could be bad memory, hard drive or other hardware.
    Try here.
    Lot's of mentions of needing XP SP2 if you have a PCI express card installed at all.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Check out memtest86+ and give that a run. I've seen just about anything cause this issue from ram to cpu to drive controller. Good luck and hope you figure it out.
    Thread moved to newbie section.
    Tidder
    Try RevFE
    Aug 2010
    i have tried memtest86+ my ram is good 4 hours with 0 errors and i have no pci card installed here is my hardware setup
    Intel D410PT
    kington 2gb ram
    kingston 30gb SSD
    Samsung 500gb hard drive
    M4-ATX PSU running on 12v adapter
    Sep 2003
    New Mexico, USA
    Switch to a desktop PSU and see if that cures it?
    Tidder
    Try RevFE
    Aug 2010
    i will try that tonight lol i dont know why i never thought of that i have about 3 PSU laying around here somewhere,i will give it a try and post back
    Sep 2003
    New Mexico, USA
    Also, another thought... try an XP disc with SP3 slipstreamed, SP2, SP1, and gold. Start from newest and work your way back, sometimes this lets me get the install on, then I can upgrade service packs afterward.
    Tidder
    Try RevFE
    Jan 2008
    Dartmouth, MA
    Even if you're not using PCI-Express cards, the board still has PCI express devices on it. For example, the onboard graphics could be a pci-express graphics card which is built into the motherboard. Even if there isn't a single device built-in that uses pci-express, the pci-express controller still exists and will need a driver.
    Also, it may be worth trying a known working cd drive.
    Also, are you installing to the SSD or to the real hard drive?
    I think I read somewhere that certain motherboards have issues with SSDs.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Aug 2010
    ATLAST i returned bios settings to default and switched to a normal PSU and it worked installed a microxp got inav to work now im having issues with centrafuse 2 everytime i start it crashes i installed dirext x and .net framework 2.0 what should i be looking at? oh and thank you guys very much for your help
    Jan 2008
    Dartmouth, MA
    Does it crash with a real xp installation?
  1. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 12:54 PM
  2. Replies: 2
    Last Post: 04-06-2006, 11:07 AM
  3. Run WinCE & XP together
    By ShawJohn in forum Software & Software Development
    Last Post: 11-07-2005, 06:09 PM
  4. TUSI-M CMedia Windows XP sound problems.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 07-19-2005, 02:45 PM
  5. Windows XP Suckage
    By vickumar in forum General MP3Car Discussion
    Last Post: 02-05-2002, 01:35 PM
