Results 11 to 20 of 28
Thread: Thinking about building a carpc (planning stage)
  1. #11
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by Bugbyte View Post
    3.5" stand up better to road abuse than 2.5" drives.
    Don't use an inverter. It introduces noise. Use a DC-DC intelligent power supply and get auto-start capability.
    this actually surprises me a bit... You would think that 2.5" drives (which are primarily in laptops) would withstand a mobile environment better than one designed to sit in a stationary desktop...
    hrm
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
  2. #12
    Sep 2010
    That really surprised me as well, i was thinking that 2.5" drives were the most robust but i guess i was wrong.
  3. #13
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    Quote Originally Posted by jonnyisback View Post
    in my opinion 2.5 drives are better, in shock and heat and cold..
    though 3.5 drives r okay but not in extreme weather.
    just don't get a 2.5 drive with a shock protection..those drives will stop working in each and every bump on the road in order to protect the drive..
  4. #14
    Sep 2010
    what about just using a 16GB flash drive for booting off of and a 32GB sdhc card for storage.
  5. #15
    Apr 2006
    Greece
    i tried a 2.5 drive..it was OK but i wanted more storage and those back then were expensive..
    i tried a 3.5 drive...it was ok but had extreme weather problems
    now i use a 2.5 drive 320 GB it is cheap and reliable and is the best i tried so far
    what i wanted to do actually was get a ssd (like 32-64 GB) for boot then use a 3.5 or a 2.5 for storage...but SSD is still very expensive
    this is my advice
  6. #16
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by tripzero View Post
    hrm
    maybe for regular 2.5" drives but not for the shock version (goes by different names) of a 2.5" drive. They have accelerometers that automatically protect the drive when you hit a bump.
  7. #17
    Jan 2008
    memory cards have very slow transfer rates-- meaning that even a ide hdd will be faster..
    for the hdd size's:
    bugbyte didn't back up the claim with any data...
    (it has been discussed to death in other areas though)
    'in theory,' a 2.5 drive's platters will move less then a 3.5" platters, which gives 2.5" drives a potential chance for less damage due to platter fluctuation..
    2.5 drives also have less mass then a comparable 3.5--both moving, and stationary mass-- so again, in theory, they 'should' be less susceptible to vibration..
    but all this hdd talk is not very useful.
    the best hdd solution is to mount the drive solidly to the case. period. no matter if it is a 3.5, or a 2.5..
  8. #18
    Sep 2010
    Quote Originally Posted by soundman98 View Post
    for the hdd size's:
    the best solution is solid-state drive (SSD)...
  9. #19
    Sep 2010
    excellent info on this thread!... i actually have a question about LCD screens... is it worth i to get a motherboard for a car pc that has dvi out instead of vga if i have a lcd screen that does only vga? i would have to put a dvi-> vga adapter to plug into the screen... will the quality be any better really?
    and i read a few times on this site saying that vga loose quality and add ghosting when they get over a certain length. is that true and if so what is the length limit usually?
  10. #20
    Apr 2006
    Greece
    Quote Originally Posted by juice_e View Post
    no improvement in my opinion.. i would get whatever i find, if your lcd only has vga, then both ways are OK.. but think about the future.. maybe your future lcd will have dvi or hdmi..
  1. New MM Plugin - HUD Display (Planning stage)
    By NiN^_^NiN in forum Map Monkey
    Last Post: 03-21-2005, 08:28 PM
  2. Rebuild (Planning Stage)
    By djXternal in forum General Hardware Discussion
    Last Post: 03-04-2005, 01:03 PM
  3. Building a CarPC...
    By Kusanagi_Kei in forum Newbie
    Last Post: 08-25-2004, 03:19 AM
  4. planning stage is almost complete!
    By pdub in forum Newbie
    Last Post: 07-16-2004, 12:02 AM
  5. Help with building my first CarPC
    By nickmv in forum General Hardware Discussion
    Last Post: 01-31-2004, 12:07 PM
