Results 1 to 9 of 9
Thread: Qube Or Fusion Brain? That Is The Question
    May 2008
    Nassau, Bahamas
    Post Qube Or Fusion Brain? That Is The Question
    I am trying to decide on which hardware should i go with. The Qube which is less expensive but can i use the same software from fusion for it? Or The Fusion brain which is a little expensive but allows individual programming etc etc.
    My automation i want to setup is
    HVAC Control
    Inside & Outside Temperature Control
    AMP Control (on and off)
    ODB II Control (on and off)
    Or do you think it makes sense i control both amp and odb using a toggle switch or a push button switch, or actually use both manual and automatic control. Any ideas? I am driving a 03 Neon, will this be possible?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Personally i would go with the fusion brain. Its tested, reliable, and more widely supported. See my plugins for RideRunner and Centrafuse as examples
    Live mp3Car Facebook Chat
    May 2008
    Nassau, Bahamas
    Ok point me to the right link..i have centrafuse 3.1
    Sep 2007
    Raleigh, NC
    I personally use the Fusion Brain and am very pleased. I cant speak to which is better since I havent used/thoroughly researched the qube.
    May 2008
    Nassau, Bahamas
    Ok Fusion Brain it is, i will have to find a few persons to assist me with the setup of the fusion brain, to make those above automation's possible.
    Mar 2006
    Colorado, but Canadian!
    I vote for the Fusion Brain...
    Did anyone else see that one coming?
    1.9in x 2.9in -- 47mm x 73mm
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by IslandBoi View Post
    http://forums.fluxmedia.net/plugin-d...n-cf3-1-a.html
    this plugin is all the configuration you'll need for each of the things you wish to do. The hookups however are all up to do lol
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    I've not gotten my hands on a Qube... Yet. Hopefully I'll have one mid-week next week to play around with and be able to give a side-by-side comparison of it with the Fusion Brain, Phidgets InterfaceKit, and possibly even an Arduino (bit different, but capable of some of the same stuff).
    Play with it, 'til it's broke.
    Jan 2008
    as of now, i would also feel more comfortable recommending the FB. the qube seems like it is going to have a lot of features that the Fb lacks(like routing certain features without a need for a pc).
    but, last i checked, colin was getting held up with some personal stuff, and the programming software needed work...
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Vista won't see the Fusion Brain
    By Ineffigy in forum Fusion Brain
    Last Post: 11-26-2008, 07:39 AM
  3. Replies: 3
    Last Post: 09-23-2008, 10:00 PM
  4. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  5. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
