Results 1 to 10 of 15
Thread: need low TDP CPU but no Atom!
    Nov 2010
    Hi There,
    I am currently planning my first car pc.
    As power source i want to use a pico-type psu and I think that i will go with a mini itx board.
    I now searched for suitable CPUS but I didnt find any ones that are lower than 45W TDP. Compared to a D510 Atom which has 13W TDP this is very much!
    What are low TDP CPUs and how much heat can I save by underclocking the CPU?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Look into mobile processors. Lots of the Core 2 Duos are 25w TDP.
    Tidder
    Try RevFE
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    If power is the consideration, take a look at the IGEP V2 from ISEE or the Beagleboard XM. It is a linux embedded device that is extremely low power.
    Want to:
    Nov 2010
    thx for the advices!
    Acutually i want to run Win7 x64 and Centrafuse as frontend so a linux embedded System is out of discussion! The embedded Sys will also have even lesser guts than the Atom!
    25W TDP sounds interessting. Which socket do this core2duos use?
    I only know the socket P which is outdated and the socket 988 which is only used on mobile boards afaik.
    Sep 2003
    New Mexico, USA
    There are lots of Socket P processors on newegg and as far as motherboards go, a quick search turned up this http://www.newegg.com/Product/Produc...82E16813153174
    I guess you are stuck with "outdated" socket P if you don't want to go atom and need a low power processor. Sounds like you need to do more research and see what's out there.
    Tidder
    Try RevFE
    Nov 2010
    LA County
    Search for "Core 2 Duo Mobile" on newegg.com. The CPUs start at $215, not cheap.
    Somebody on another thread mentioned AMD Ontario and Zacate, forthcoming Q1 2011.
    Basically if money is no concern and you need it now, buy a C2D Mobile. If money is tight and need it now, Atom is hard to beat. If you can wait a few months then wait for the new AMD offerings. Those would be my choices in the low TDP CPUs.
    May 2010
    Moncton, New Brunswick, Canada
    AMD has Socket AM3 processors at 25 Watts TDP, 270u 2.0 GHz.,260u 1.8 GHz. and 250u 1.6 GHz. They also have a 20 Watt 160u 1.8 GHz. These are dual core, 2 MB L2 cache (250u is 1MB). Click on link http://www.amd.com/us/products/deskt...omparison.aspx for more specs.
    www.shopblt.com has the 270u listed at $91.16 USD, 260u $90.94,250u $78.76 and 150u at $48.76
    www.pcsuperstore.com also lists these processors
    A warning, no one keeps stock, BLT says it takes 15 days to order in, but my experience is 3 weeks to arrive and 1 more week to ship, and don't get it shipped USPS priority parcel, or it's 2-3 more weeks to arrive.
    You can get a Socket AM3 785GX-SP128M for $129 at
    http://www.mvixusa.com/shop/index.ph...roduct_id=1600
    Or a Socket AM3 890GX-USB3 for $199.00
    http://www.mvixusa.com/shop/index.ph...roduct_id=1613
    NVix is a US company, so you should be able to RMA the motherboard if it doesn't work or malfunctions under warranty. I haven't checked on other manufacturers of mini ITX AMD boards.
    Don't ask the quality of the J&W Minix motherboards, I have the 890GX-USB3,(nice board, VGA/DVI/HDMI, So-Dimm PC3-850/1066,comes with N WiFi and Bluetooth adapter, PCI-e, USB3 and SATA III) but waiting for my 270u CPU to arrive by snailmail.
    I've never underclocked a AMD CPU, but imagine it depends the same as overclocking, some from one batch might work OK, other's not. The 780GX-USB has the ability to Under/over clock CPU's, and if you upgrade to a newer board later on, you can always put in a 6 core and use it for a home entertainment unit.
    Nov 2010
    ty, for the advcie! The Athlon II X2 270u looks very very promissing.
    Unfortunately it isnt aviable in germany yet but I have to wait about 6mounths till my car arrives anyways.
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Intel Celeron 430 and 440 are 35W cpu's available now. I've had one in my carputer in the past and it worked great. I'm running a 65W e5200 now just because I wanted to try watching TV (ATSC) and needed a bit more horsepower to decode HDTV, but the 430 worked so well that I have a home server based off one as well.
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
    Dec 2008
    i run a celeron 430. its plenty fast enough, even though i get a lag after saying commands.... i think i have a software problem though. its a night and day difference over an atom setup though.
    edit- fixed my problem! debugging for rrvoice was set to OFF in the config program, but once i went into the rrvoice.ini file i noticed it was set to TRUE. i wrote in False and now everything is instant.
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2012, 02:35 PM
  2. Intel D201GLY2 low profile fan upgrade success! [pics]
    By maniaxzero in forum General Hardware Discussion
    Last Post: 02-16-2008, 10:12 AM
  3. VIA/S3G Unichrome 100% Cpu usage.
    By Injector in forum Software & Software Development
    Last Post: 11-11-2007, 10:41 AM
  4. Motherboard or CPU....which one's dead?!
    By Munkeyd00d in forum General Hardware Discussion
    Last Post: 04-05-2006, 01:02 AM
  5. COMMELL LV-667T w/ VIA C3 1.00GHz CPU INFO please
    By KF4ODQ in forum General Hardware Discussion
    Last Post: 08-10-2005, 04:10 PM
