Results 1 to 9 of 9
Thread: Calu-M2C Power on question
    Feb 2006
    Question Calu-M2C Power on question
    Hey Guys,
    Had this baby installed a meelion years ago, but then car went through some changes and now im finally installing it again.
    I connected it as follows:
    Red: constant power
    white: negative / ground
    Green: ignition switch (ie: gets 12v when i turn key to "1")
    However, the computer isnt switching on upon turning my key or even switching on my car. Is the above wiring incorrect? I didnt change the bios settings or anything like that, so should all be the same and it used to work way back when ?
    TIA!
    Feb 2006
    After further investigation, I see that it doesnt power on upon ignition when i have my CTF700 screen's usb port attached - but with it disconnected, it works - what gives?
    Jan 2008
    have you tried connecting the screen to another pc?
    Feb 2006
    Hmm, will have to organise a laptop to check it out :S will revert back once i know what happens...
    Feb 2006
    So I got a laptop and the CTF700-SH does the exact same thing to my laptop, (though a bit different - power goes on, but the screen stays black and so doesnt go through post or anything). Works fine if I unplug the USB port of the CTF700 - but with it in, bam - no go!
    What gives?!? TIA!
    Jan 2008
    sounds like a bad touch overlay, or touch controller. you'll either need to replace both, or replace the screen..
    Feb 2006
    Damn!
    How do I go about checking which of thw two it is and how do I replace the two?
    Jan 2008
    i'm not really sure.. try checking the lcd section.
    Feb 2006
    Quote Originally Posted by soundman98 View Post
    Just for future reference, for anyone who has this issue - for me, it was because of a fault USB extension cable connecting the touch panel.
  1. Is this old CALU or what??
    By Huicca in forum General Hardware Discussion
    Last Post: 01-20-2008, 04:18 PM
  2. power question higher power psu a problem?
    By crualmofri in forum Power Supplies
    Last Post: 10-23-2007, 08:57 AM
  3. Power Question
    By jwcullen in forum Power Supplies
    Last Post: 02-10-2005, 06:21 PM
  4. CALU P4 Barebone
    By Goose in forum General Hardware Discussion
    Last Post: 01-16-2005, 07:20 AM
  5. Power Question/Setup Question, minibook pc
    By seamonkey420 in forum Newbie
    Last Post: 05-17-2004, 10:47 PM
