Results 1 to 3 of 3
Thread: CarPc for Dodge Charger Help
    Mar 2011
    I'm a newbie to carpc but not to the pc world ..... i want to put a carputer setup in my wife's charger along with a full system 2x 10' kicker's mids/highs 2x amps but i just installed the eclipse navigation is it possible to keep the eclipse navigation as a monitor by using the video input (ex: as hooking it like a playstation in car) and use a keyboard and mouse to run the carputer cause i will assume that the eclipse will not be able to run the carputer using the touchscreen
    Maximum Bitrate PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Yes, you could send the audio through the headunit. The windows desktop & front end should show up on the screen through a video input but you are correct, no touch screen. I don;t know what size you will use to get the desktop to fit properly so you will have to experiment with that unless someone else chimes in that has done this.
    Jan 2008
    you just need a vga to composite signal converter. it is discussed a little in this thread:
    http://www.mp3car.com/newbie-propose...ompatible.html
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  1. 2007 Dodge Charger & Zotac Ion
    By rtgree01 in forum Worklogs
    Last Post: Yesterday, 10:01 PM
  2. Dodge Charger iPad Install
    By MobileEVDO in forum Apple iPad
    Last Post: 09-04-2010, 01:23 AM
  3. Dodge Charger Carputer Install
    By KOMO in forum Worklogs
    Last Post: 05-22-2010, 02:29 AM
  4. Dodge Charger Skin?
    By ekaz in forum StreetDeck Skins
    Last Post: 05-29-2008, 03:52 PM
