I recommend not using the netbook as the base for your setup. I actually have the same netbook as you and I had attempted to use it once. It worked out but I disliked the fact I had to install and remove the netbook each time I used my vehicle. I went back to a more traditional setup and now use a Via mini-ITX motherboard installed inside an aluminum case tucked away out of sight.
LinkBack URL
About LinkBacks
