Results 1 to 8 of 8
Thread: Power to charge laptop
    Apr 2011
    Newcastle-upon-Tyne, UK
    Hi, have searched forum and couldn't find an answer to this...
    Is there a way to hook up the laptop powerbrick thing so that I don't need to buy an inverter?
    Laptop runs off 11.4v and I'm planning to use the battery for power on / off so this would just be hardwiring it so that it charges when the engine is running... is this 11.4v dc? how would i check?
    I know I could probably just use an inverter (thing that plugs into cigarette lighter that gives a normal power plug socket) but they are quite big and bulky and don't really want to accomodate one in my car...
    ta peeps
    Jan 2008
    nope. you'll either need to get a inverter, or use a dc-dc power supply.
    Elsewhere
    Laptops (and other charging systems) typically don't play nice with inverters.
    You should look for an auto adapter for your laptop.
    If you can't find one, there are Carnetix regulators that output 12vDC that will likely work nicely for you.
    How about the Wiki?
    Apr 2011
    this the right thing?
    if so bonus!!! cheaper than the new battery I'm gonna need!!
    cheers!
    Jan 2008
    you didn't post the laptop model, so i can't be sure. but it says it outputs 19v instead of 11v.
    Apr 2011
    sorry... it "was" a dell inspiron 1525...
    Jan 2008
    then yes, that should work
    Apr 2011
    Woop woop!
    Its all coming together nicely now!
    Hardest part seems to be getting a reasonably priced screen!
  1. carnetix to power a laptop as well as charge its battery?
    By sharpmusic in forum How to Power a Laptop
    Last Post: 08-20-2009, 01:15 PM
  2. how to power laptop and charge battery with carnetix
    By sharpmusic in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 06-29-2009, 06:20 AM
  3. Power your laptop/mobile device wirelessly- (Wireless Power Induction)
    By hexxamillion in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 04-03-2009, 11:07 PM
  4. Have power to my laptop but it does not charge the battery
    By derbis in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 01-07-2006, 12:52 AM
  5. Split charge Relay and power drain
    By slarty in forum Power Supplies
    Last Post: 11-06-2003, 01:49 PM
