Right... should be nearly ready to start the build for my car pc..
Have a couple of things to ask before I start....
The laptop is currently caseless ... will I need to make some kind of heat shield for under the board? Or can I screw it directly to mdf? It won't be screwed flat against the wood as the battery will be attached and lift the laptop board up...
Also how close can the Ómp and laptop can be to each other? Will the amp affect HD or anything?
Contemplating either passenger footwell or boot... or possibly both if they need to be separate...
