Results 1 to 10 of 18
Thread: Newbie with Auto-Power Issue =(
    Apr 2011
    Hey guys,
    I've been doing this carputer for my first time and I can get the computer working by pushing the on button and screen working fine however I can't get the computer to auto turn on with the ignition...
    From what I gather:
    Black wire to black on battery,
    red wire to ground on car,
    grey wire to an ignition but it's just not happening for me =(
    Could anyone shed some light on this issue for me please?
    Apr 2011
    Red wire to ground?!?!?
    Should be black to ground and red to possitive battery terminal
    Jul 2010
    What power supply are you using?
    Apr 2011
    It's an M2-ATX
    Jan 2008
    speedyvr6 is correct.
    the black wire goes to ground, and the red wire goes to the +12v terminal on the battery. just be sure to fuse the wire within 18" of the battery(i prefer less then 12", but iasca spec is 18"...)
    and yes, the white wire would typically go to a switched source, like a ignition line. the alternative is to connect a switch off the red wire to control weather the white wire recieves power. this would perform the exact same function, but would not automatically turn the pc on/off.
    Apr 2011
    Thanks guys, makes sense. Am sat in my car now and still not having much luck with this.
    Power is getting to the carputer. Red is now red with battery, black is grounded and white just seems to be doing nothing to autostart the computer, no matter where I stick it (no funny comments please :P) there seems to be no signs of an autostartup!
    Apr 2011
    Okkkkk, got it to bootup on ignition by changing the BIOS yeay!!!
    Issue I now have is that when I switch the car off the computer has hard shut off instead of shutting down nicely. Anyone with more idea why than me? Any help is appreciated, thanks
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    What FE are you using?
    In CF, there is a setting in the menus to adjust what action you want the PC to take when power is cut.
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    rubber chicken, see if your jumper is set to "A" on your M2-ATX which gives you a five second delay for startup/shutdown.
    Good Luck.
    Apr 2011
    Having problems loading Cf which is a different issue altogether
    Also I'm gonna sound numb but jumper set to A? I'm a noob doesnt mean much to me sorry!
    I 'think' a jumper are those double prongy things on the boards? And how do I set it to A?
    Thanks...and sorry
    Having troubles again with ignition booting too! Arghhhh
  1. Replies: 0
    Last Post: 02-22-2011, 01:49 AM
  2. Bluetooth Auto Answer Issue
    By bratnetwork in forum Wireless Communications
    Last Post: 07-17-2009, 09:37 AM
  3. Newbie PhoCo Issue
    By mjmaalej in forum PhoneControl
    Last Post: 06-20-2007, 07:31 PM
  4. Newbie power issue
    By scotty562 in forum Newbie
    Last Post: 11-07-2006, 12:00 PM
  5. Lilliput auto power on issue...
    By Rs! in forum LCD/Display
    Last Post: 06-08-2005, 01:34 PM
