Results 1 to 5 of 5
Thread: Double Din Bezel question
    Aug 2010
    Hi Guys I bought my new car and I have a question for you
    I have a Hyundai Accent 2011 my dash looks like this
    http://www.mp3car.com/vbimghost.php?...img&imgid=6978
    I would like to know If I buy this Monitor
    http://www.mo-co-so.com/Double-DIN-L...lil-701-dd.htm
    Do I need This bezel to make this fit perfectly in my car ?
    http://stores.caraudioproshop.com/-s...Kia/Detail.bok
    DO I need Both and will it fit Perfectly like this Picture " From a KIA but Hyundai/KIA Has the same Bezel"
    I don't want to spend 200$ on a Premade DoubleDin Monitor + 20$ on a DoubleDin Bezel and End up that it does'nt fit!!!!So please Let me know
    http://i143.photobucket.com/albums/r.../Photo0023.jpg
    Thanks for your reply!!
    Jan 2008
    it appears that you will need that bezel to correctly fill in the area around the screen.
    but there is a easy way to determine that-- din specs are 2" tall, by 7" wide, so double din is 4" tall, by 7" wide. just measure your dash-- if the opening is larger then that, you need the trim ring kit..
    Aug 2010
    Ok So This piece : http://stores.caraudioproshop.com/-s...Kia/Detail.bok
    is supposed to be 4" Tall By 7" Wide right ?
    This Bezel is suposed to fit perfectly My Accent ? So what is the Monitor IS Too large for the bezel Is that possible ?
    I Really don't understand Double Din Size lol
    Jan 2008
    'din' is, or used to be, the accepted standard for the height, and width of head units.
    the mo-co-so link-- the 701 screen with the bybyte frame abides by this standard-- so it is 4" tall, by 7" wide.
    your car appears to have a opening slightly larger then din standards, so while the screen will fit, there will be a slight gap around the screen. the point of the the piece is to adapt your slightly larger car-opening to din standards, so the screen should fit correctly.
    Aug 2010
    OK Nice I understand now!! SO it's supposed to fit with those 2 pieces
    EDIT : So I'll buy the 20$ Piece and see if it fits perfectly to my Accent .. If It does fit and there is no "GAP" the inside of the Bezel would have 4 Inch Tall and 7 Wide
  1. Does a 619 screen fit in the mp3car double-din bezel?
    By Gibson99 in forum MP3Car Products - store.mp3car.com
    Last Post: 05-25-2010, 09:09 AM
  2. Which bezel? Double DIN 7"
    By VibinAudio in forum Fabrication
    Last Post: 05-11-2010, 09:31 AM
  3. My new BMW E90-E93 Double-DIN Bezel...
    By srcstc in forum Show off your project
    Last Post: 11-16-2009, 09:01 AM
  4. FS - WRX Double Din TMZ Bezel and VGA Lilliput LCD Touchscreen
    By RR BuGGz in forum Classified Archive
    Last Post: 04-30-2006, 12:02 PM
  5. Replies: 21
    Last Post: 03-22-2006, 12:17 PM
