Results 1 to 8 of 8
Thread: Valet Switch to M3-ATX PSU
    Apr 2011
    Just want to preface with with the disclaimer that I *DID* use the search function, but was unable to discover the information I need.
    WHAT I WANT TO ACCOMPLISH: I'd like to be able to install a switch that will prevent my computer from booting up / waking from hibernation when the switch is set to the OFF position, and have it boot / resume as normal when set to the ON position (which will be the majority of the time) -- I'd like to have it set to not boot at all when I'm making a short trip, or just moving my car from one parking space to another.
    The M3-ATX has 3 connections: power, ground, and ignition, all wired into quick disconnect terminals.
    I'm a complete novice with electricity, and I don't pretend to understand the majority of what I've already read about valet switches, but I'm always interested in learning, in fact, I'm interested in picking up some "Idiots Guide to Electronics" projects (like the ones Rat Shack used to sell) to learn a bit more after I complete this car pc project.
    Without a valet switch to do what I want to do, I presume the wiring scheme would look something like this:
    Battery -> In-Line Fuse -> 10 AWG -> Power wire on M3-ATX
    Ground Bolt In Trunk -> 10 AWG -> Ground Wire on M3-ATX
    Wire Tap to IGN Wire under steering wheel (Blk & Yellow Wire according to the haynes manual for my vehicle) -> Higher Gauge AWG (To Be Determined) -> IGN Wire on M3-ATX
    I understand, I may be suffering from delusions of grandeur, and that all of the above might be incorrect, but that's how I understand it thus far. Please correct me if I'm mistaken.... and with that... what type of switch I'll need (rocker?) and how to wire that into the setup to accomplish the aforementioned task. Thank you in advance!!!
    Low Bitrate agentq's Avatar
    Nov 2010
    Escondido, CA
    Well one option would be to get a 2 way switch and connect it along the signal wire going to the power supply. Pretty much if the switch is off the signal wire is cut therefore no power gets to the carpc to tell it to turn on. When switched to on, the signal wire is restored leaving power to signal the carpc power supply to turn on.
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Quote Originally Posted by agentq View Post
    That's what I did. Since I use the ignition wire from the radio harness, I just put in a simple lighted rocker switch on the dash so I can turn the computer off/on whenever I want.
    You don't need a huge wire for the ignition wire. Just use 14-16GA and you'll be fine.
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Jan 2008
    the answer is correct, but i feel that someone new to electronics might not get it--
    any standard switch will work for this-- don't worry about getting a "2-way switch". all the switch needs is to have a common terminal, and a normally open terminal, and to make sure that it is not a momentary switch.
    Apr 2011
    Quote Originally Posted by soundman98 View Post
    Thanks for the reply... So something like this would do the trick?
    http://www.autozone.com/autozone/acc...er=976435_0_0_
    I also noticed a lot of these have 3 "prongs" for lack of a better term... Where would I look up info on correctly wiring one of these? Thank you!
    Nov 2010
    Escondido, CA
    Yes that switch would work. I would assume the reason some have 3 prongs is because it has a light on it. Somone can correct me if im wrong but if there is no light odds are its going to have two prongs and you would just put that inline on the signal wire. If it has 3 prongs its the same hook up except now it has a prong for ground for that light to work.
    Jan 2008
    ^ yup-- the difference is that the switch requires a ground connection for the led to light up.(i've got 8 similar switches in my car).
    Variable Bitrate Superduck's Avatar
    Oct 2003
    Vancouver BC
    SPDT Switch?
    [EDIT]
    See, I said I knew I saw it somewhere. For what it's worth, I was looking for an on-off-on to do always on, always off and regular ignition control.
    The answer was here.
    However, I noticed one of the last posts was talking about switching from normal mode to always-on mode, would probably trigger the computer to shut down. Would there be an easy way to stop this from happening without using another switch? Perhaps a small capacitor on the line? It'd only delay shutdown by an extra couple seconds, correct? What value cap would work, should this method work at all?
    [/EDIT]
    Cheers,
    Kris
    How Much Horsepower Can I have And Still Go To Heaven?
  1. 3-in-1 (always on/always off (valet)/normal) switch?
    By Tical84 in forum Power Supplies
    Last Post: 06-03-2010, 12:09 PM
  2. Valet Switch
    By benny32 in forum Newbie
    Last Post: 04-27-2010, 09:07 AM
  3. FB powered valet switch... is this right?
    By Sonicxtacy02 in forum Fusion Brain
    Last Post: 05-02-2009, 02:01 PM
  4. Valet Switch HELP!
    By Nickwell24 in forum Newbie
    Last Post: 03-18-2008, 12:22 AM
  5. Valet switch for carputer?
    By Ramanator in forum Newbie
    Last Post: 07-17-2007, 10:56 AM
Tags for this Thread
