Page 1 of 6 123456 LastLast
Results 1 to 10 of 53
Thread: VW Transporter T5
    May 2011
    VW Transporter T5
    Hi guys
    First thread so go easy on me.
    I recently purchased a double din DVD player etc to fit into my VW T5, all went well accept when fully installed, the screen is barely readable due to the height of the unit in the dash and the angle at which it sits.
    Having pondered this issue for the whole of my bank holiday weekend, and reading through loads of threads on here. I am now thinking of completely forgetting the headunit and going for carpc with screen mounted in the dash.
    Having read up on modifying the dash for three days, i am now a little confused as to where the start. Basically, i completely understand the different methods of glueing/ fixing different types of plastics. May main query at the moment is how do you identify which plastic is which. I have no idea what material my T5 dash is made from nor the Lillput screen i intend purchasing.
    Any help would be really appreciated.
    Thanks s
    Jan 2008
    usually there are logos/symbols on the rear of the plastic piece that should indicate the material it uses.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    May 2011
    Thanks Soundman, i did answer this last week but seems to have gone missing.
    Think i ll go down the modifying a Bybyte frame for a lilliput.
    Any advice on a mothermother? looking for 2 video outs being a van, thinking of the asus atom 330 at3iont
    but not sure on compatible psu.
    Any ideas?
    Jan 2008
    not really-- i prefer name brands like asus, gigabyte, and intel, but really don't have any specific likes/dislikes within those brands--just whatever fits the build.
    HID retro--100%
    May 2011
    Right modding of the dash panel is well under way, decided to go down the ABS goop road, takes an age to go off so decided to post up my shopping list for my build.
    Asus atom 330 at3iont
    2GB DDR3 SDRAM
    M2-ATX psu
    64GB SSD+60GB external HDD(from old laptop got knocking around)
    Slimline DVD drive TBC
    VoomPC 2
    Alpine CDE-9850Ri HU
    lilliput 669gl/ Bybyte frame / second screen to come later
    Windows 7
    RoadRunner/ elite lite
    Would apreciate it if any of you guys could take the time to posts your comments/ views / tips, i ll keep reading up.
    Thanks for your ideas
    Jul 2010
    Alpine CDE-9850Ri HU -- why?
    If you're doing a CarPC then there's no need for this..
    May 2011
    was sort of thinking this would be the amp, set up in the back somewhere, so could also use it to control volume listen to radio etc whilst fishing camping whatever.
    Got me thinking now, this not good idea then??
    Jan 2008
    Quote Originally Posted by infinateflea View Post
    it is perfectly fine-- many run the carpc into the hu so that they can have radio/cd even if the carpc isn't on, or isn't working, or in your case, a simple solution for volume control+amp... it's kinda like having 2 ipods-- a little excessive, but sometimes is what you need to fit your requirements..
    HID retro--100%
    May 2011
    Build is coming along, components arriving, dash mod taking forever.
    I think i got most of the wiring sorted just bit of head scratching with the Asus atom 330 at3iont and the M2-ATX. I ve plugged the 2 pin connector to the M2 J8 motherboard on/off switch, but on the MB all i can find is a system panel connector (10-1 pin F_PANEL). Do i connect to just the PWR BTN gnd and pwr? and forget the other pins.
    May 2011
    Hi
    I ve drawn up a rough wiring diagram for my T5 below, hoping someone here can take a look, let me know your thoughts.
    Thanks S
  1. VW Caravelle/Transporter (T5) wiring
    By quango in forum Newbie
    Last Post: 08-19-2010, 09:46 AM
  2. Volkswagen Transporter T5 pimping!
    By portreathbeach in forum Show off your project
    Last Post: 03-17-2010, 01:23 AM
  3. 1971 Volkswagen Transporter
    By Pokiarchy in forum Worklogs
    Last Post: 02-05-2007, 02:38 PM
