Results 1 to 8 of 8
Thread: Can't get fuse out of amp! Need help
    Jun 2011
    So my subs stopped working a bit ago and I haven't excessively bumped them so they couldn't have just blown.
    The light on my amp (alpine v power mrp-m1000) kicks on just fine and my head unit still displays the option for my subwoofers settings. So I'm thinking that maybe a fuse was blown in it. I had that problem with my last sub and amp set.
    My trouble comes in when I try to take the fuses out to look at them. I can't get the damn things to budge at all. Pliers don't work, wiggling it side to side doesn't work. Is there a locking mechanism that I've missed?
    And if anyone has any other advice about my sub problem, I'm all ears to other possible solutions.
    Jan 2008
    try pushing it in a little first?
    desolder the fuse holder?
    replace the amp?
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Pictures could help. Is it circular? If it is I would try push in and turn left? If it's not, have you look on the inside and pushing from there? Just shooting in the dark here.
    Jun 2011
    I will definitely post some pictures tomorrow after work.
    Low Bitrate sk8rjess's Avatar
    Nov 2007
    i have heard of and seen fuses getting so hot they "solder" to the fuse holder, that may be what happened here
    they call me hack
    Independence Auto Tech
    http://ctxdesigns.com - web design :)
    "Let us search out and examine out ways, and turn back to the Lord; Let us lift our hearts and hands to God in heaven." - lamentations 3:40-41
    Jun 2011
    Sorry it took so long, here are two pictures of the fuses that I can't get out of the amp. One seems to be somewhat coming out, but that was after 8-10 minutes of pulling on it with pliers. Anyone have any experience with this problem?
    Raw Wave
    Nov 2009
    They can be tight, but they should pull. Wiggle a bit up & down - the "sockets" are mere female spade terminals - you can see the terminal's wrap over on the middle fuse, top RHS.
    It is unlikely that solder has flowed that far.
    And they should not have been glued in.
    Only if plating has occurred should there be a problem, but then you'll probably need to replace the sockets anyhow....
    A likely replacement:
    (Narva Product Code: 54394BL)
    Other types:
    Typical "spade" connector - same end in many OEM blade fuse holders:
    Jan 2008
    your already trying what i do-- pull on them with a pliers..
  1. fuse-tapped fuse keeps blowing.
    By Snortonnorton in forum Power Supplies
    Last Post: 09-19-2007, 01:49 PM
  2. AMP Fuse or Inline Fuse
    By ijwalla in forum Newbie
    Last Post: 04-01-2007, 12:14 AM
  3. fuse the pc?
    By LVExpo in forum Newbie
    Last Post: 02-23-2006, 09:44 AM
  4. what needs a fuse?
    By Heedunk in forum General MP3Car Discussion
    Last Post: 11-13-2005, 06:51 AM
  5. what fuse holder/fuse amp ratting to get?
    By [H]Bugster in forum Power Supplies
    Last Post: 12-08-2003, 01:53 PM
Tags for this Thread
