Results 11 to 20 of 25
Thread: Subaru Newbie - Alternative way to shut Car PC down
  1. #11
    Jan 2008
    it's really hard to know without seeing the car in person. in most cases, no you won't. but murphies law says otherwise..
  2. #12
    Jun 2011
    Sydney Australia
    Will try and re-wire it myself over the next few days,with the a ATX power supply which setting is the best
  3. #13
    Jan 2008
    i would be fine with mode '1', but it is all personal preferance..
  4. #14
    Jun 2011
    Sydney Australia
    Quote Originally Posted by SUB-1 View Post
    Hi guys, I have just spent all afternoon rewiring the car PC. I have placed an 8 gauge positive wire directly to the car battery with an inline fuse. I then put a new 8 gauge positive wire to the body of the car. I also have run a new wire into the fuse box to obtain accessory power. I opted for option one for the power output connectors on the M2 ATX power supply and I have also run an additional on/off button from the PC into the side console. If I don't put my computer into hibernation mode (with the power settings) when I turn the car off, it shuts off normally but when I start the car, it doesn't resume from where I turned it off. Instead, the computer reboots like its power has been interrupted. However, if I do press the on/off switch and put it into hibernation mode before turning the car off, everything works as it should. Is this normal?Sorry for silly questions
    Cheers George
  5. #15
    Jan 2008
    i assume you mean you connected a 8 ga negative wire to the car chassis-- otherwise, it would be a dead short
    mode 1 might not be enough for the pc to save the hibernate file--after 45sec, the psu turns off completely, reguardless of what the pc is doing.. a easy way to test this would be to try mode 2, or 3, and see if the psu will correctly trigger, and maintain the hibernate.
  6. #16
    Jun 2011
    Sydney Australia
    Quote Originally Posted by soundman98 View Post
    Hi, well I have set the power button on the PC to hibernate so what I do is before I turn the car off, I hit power button, wait around 10-20 seconds and then turn the car off. Is this the normal shutdown procedure for a car PC? Are there alternative methods which make it easier?Also have put the ATX to mode 2
    Cheers George
  7. #17
    Jan 2008
    yes, there is alternative.
    connect J7 from the M2 to the motherboard power switch pins. this will allow the m2 to turn the pc on/off whenever you turn the car on/off.
    in mode 2, it would take care of everything, and leave enough time for the carpc to fully hibernate.
  8. #18
    Jun 2011
    What case are you using?
  9. #19
    Jun 2011
    Sydney Australia
    Cheers Soundman98, but I have already done that still not sure why I cant get it to work right.
    Cheers George
  10. #20
    Jun 2011
    Sydney Australia
    Quote Originally Posted by Auvee Bloomberg View Post
    Sorry what do you mean .. case
  1. Subaru LGT - Newbie needs software help
    By MrCali in forum Newbie
    Last Post: 10-21-2010, 07:16 AM
  2. Newbie PSU/Shut down controller questions
    By rudetrini in forum Power Supplies
    Last Post: 10-08-2008, 09:19 AM
  3. PC shut off on it own
    By cyn in forum General Hardware Discussion
    Last Post: 04-03-2006, 08:16 AM
  4. Moving Car PC from Subaru Impreza to Subaru WRX?
    By Arathranar in forum General MP3Car Discussion
    Last Post: 03-31-2006, 06:52 PM
  5. XM-PCR, GPS, Shut Down
    By edikp in forum Media Engine
    Last Post: 06-18-2004, 11:26 AM
