Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Subaru Newbie - Alternative way to shut Car PC down
    Jun 2011
    Sydney Australia
    Hi everyone, I've just built a car PC and everything seems to be working so far. These are the products I have used:
    Gigabyte GA-D525 Mini ITX motherboard with Intel Atom dual core 1.8ghz
    * 4GB ram Kingston
    * 500GB Seagate 2.5" HDD
    * M2 power supply Mini-ITX M2 Car PC DC-DC 160W 8V-28V ATX Power PSU 12V
    * Micro ATX PC Car Chassis case
    * Lilliput 7" 669 GL-70NP/C/T-H HDMI ultra bright 450cd/㎡ touch screen
    * Globalsat BU-353 USB GPS Receiver SIRF III
    * 4 port USB hub (powered)
    * Tactrix 2.0 cable
    Software:
    * Windows 7
    * Centrafuse 3.6
    However, I am looking for a way to turn the PC off as soon as I turn the motor off (without having to manually put it into sleep mode while the car is running). I've purchased an MpegBox uSDC20D micro shutdown controller but I don't know if it is going to solve my problem. Does anyone have any suggestions as to how I can do this? Also how much power does the PC draw when it sleeps
    Cheers George.............. NEWBIE
    Jan 2008
    why don't you use the m2 shutdown controller, and configure windows to enter sleep mode on the power button press?
    Jun 2011
    Sydney Australia
    This is still all new to me as computers are not my strong point
    Low Bitrate sk8rjess's Avatar
    Nov 2007
    Quote Originally Posted by SUB-1 View Post
    may not have been the best project to tackle then.
    nah man i'm kidding. luckily you're at a great forum with alot of helpful people.
    your m2 can handle the startup and shut down process without the need of anything else. and i don't recommend setting the system to sleep unless you have a really good battery or a dual battery setup. i know most laptops are only supposed to use <= 1.7watts. i have no numbers or anything, but i'd say carpc's would be right around that as well. some batteries just can't handle that draw after a couple days - which is why the PSU's have a hard off after X seconds setting
    this link will tell you how much your system is drawing:
    http://www.antec.outervision.com/
    glance through this:
    http://www.mp3car.com/products/Power...ATX-manual.pdf
    they call me hack
    Independence Auto Tech
    http://ctxdesigns.com - web design :)
    "Let us search out and examine out ways, and turn back to the Lord; Let us lift our hearts and hands to God in heaven." - lamentations 3:40-41
    Jun 2011
    Sydney Australia
    Thanks guys, I will look at that. I think that my installer has used the J1 wire lead and hooked it up to the cigarette plug for a power source. This might be my problem.
    Cheers George
    Jun 2011
    Sydney Australia
    Quote Originally Posted by sk8rjess View Post
    Thanks guy will look at the power supply hook up,I have a feeling that the installer has used the J1 lead and drawn power from the cigarette plug as power source.This might be my problem DO YOU THINK.
    Nov 2007
    WHOA. if he did, you def need to redo it. it needs a dedicated power wire coming from the battery.
    they call me hack
    Jun 2011
    Sydney Australia
    Thanks sk8rjess have just called the installer he got a little ****ed, but he will fix it. Now if I keep on useing it for the time being untill I fix it will it do any type of damage.
    Cheers George
    Jan 2008
    hold on-- don't just go plugging/unplugging wires without knowing what they are supposed to do.
    J1: this gets connected via a fused wire, directly to the battery, and should always have +12v on it.
    J3: this gets connected to a wire that only has +12v when the ignition is turned to 'on' or 'run'
    J4: this gets connected to a good chassis ground-- usually bolted to the car body.
    if any of these aren't setup this way, take it back to get corrected.
    also,
    J8: this little 2 wire jumper is connected to the 'power button' connections on the motherboard.
    J10: the jumpers you install here define how long the pc takes to shutdown when you exit the car.
    Jun 2011
    Sydney Australia
    Thanks sk8rjess have just called the installer he got a little ****ed, but will he will fix it. Now if I keep on useing it for the time being untill I fix it will it do any type of damage.
    Cheers George
  1. Subaru LGT - Newbie needs software help
    By MrCali in forum Newbie
    Last Post: 10-21-2010, 07:16 AM
  2. Newbie PSU/Shut down controller questions
    By rudetrini in forum Power Supplies
    Last Post: 10-08-2008, 09:19 AM
  3. PC shut off on it own
    By cyn in forum General Hardware Discussion
    Last Post: 04-03-2006, 08:16 AM
  4. Moving Car PC from Subaru Impreza to Subaru WRX?
    By Arathranar in forum General MP3Car Discussion
    Last Post: 03-31-2006, 06:52 PM
  5. XM-PCR, GPS, Shut Down
    By edikp in forum Media Engine
    Last Post: 06-18-2004, 11:26 AM
