Ooops sorry i must have missed that/
I was just wondering now what does the red mic on the top right of RR mean and is there like a button i have to hold before i speak into the mic.
I followed this installation guide and did everything here.
## SETUP ##
Turn off RideRunners built in VR in rr.ini if you have it on.
Make sure that Voice Recognition and your Microphone is set up correctly.
1. Unzip and Drop the all files into "RRPATH"\Plugins\RRVoice"
Note: There are sample .skin and .png files (DFX4)
2. Run the batch file in the folder: "RRPATH"\Plugins\RRVoice\Register.bat
3. Open RRVoiceConfig.exe and Click the "Create" Button and let it find your MP3 and WMA files.
Note: Currently only finds MP3 and WMA Files.
You will note that you have full ini editing capabilities in RRVoiceConfig.exe.
Debug is off by default in both apps, Leave it off for now. Turn it on later if you need to debug.
You can close RRVoiceConfig.exe now if you wish.
Start RideRunner. RRVoice will start and stop with RideRunner.
On startup RRVoice will minimize to system tray, right click on it to pop it up.
RRVoice now Creates a list (RRVoice.txt) of CURRENT Commands in it's Folder by Calling "RRVOICE_LIST"
How ever when it came up to this section i didnt really understand it, maybe this is where i am going wrong if anyone can clarify it for me.
## Testing ##
Take a look at and scroll through the default commands listed in the Commands Listbox in RRVoice.
I have it currently setup with a few default commands as you can see in the Commands Listbox.
Now click on the word "VR OFF" on the RRVoice form
-or-
Use the skin commands as noted below
-or-
Use serialswitch and a momentary button, as noted below, to execute the RRVOICE_ON command
-or-
Use any input device to execute the RRVOICE_ON command.
"VR OFF" will change to "VR ON" on the RRVoice Form.
Say a command and you will see the application and RR recognize your command.
If everything is correct you will see the RideRunner command in bold at the bottom of RRVoice
and RR will execute your command.
If not. Go back and Setup or Train SAPI or Setup your microphone correctly.
I will not provide support for your SAPI VR or Microphone issues.
Sorry for wasting your time and thank you for going out of your way to read this.
LinkBack URL
About LinkBacks
