Results 1 to 4 of 4
Thread: Quick wiring question regarding power supply
    Jul 2010
    Dublin, OH
    Question Quick wiring question regarding power supply
    I'm currently running a Carnetix P1900 with the MacPac Power Cable Kit and Mac Mini Y Cable. It is currently wired to turn everything on when I turn the key to IGN.
    How would I go about changing this setup to just having it wired to a toggle switch? One position turns everything on, the other turns everything off. I want to have control over the computer, not my IGN.
    Also, would I be able to eliminate anything with this new setup?
    Thanks in advance!
    Jul 2010
    Dublin, OH
    Would it be as easy as splicing the switch in between the ground wire on the macpac cable? If the IGN was on and I flipped the switch on, it would act like normal right?
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    All you would need to do is disconnect the yellow wire (input side of the 1900) from the accessory line on the vehicle and connect it to one side of a toggle switch. Connect the other post of the toggle switch to the red wires on the input side of the 1900 which are connected to a B+ line on the vehicle.
    Jul 2010
    Dublin, OH
    Quote Originally Posted by PhilG View Post
    Thank you sir!
  1. help!! quick wiring question!!
    By jamiegolf in forum General Hardware Discussion
    Last Post: 11-25-2008, 05:37 PM
  2. Power Supply Quick Question
    By redcell3 in forum Power Supplies
    Last Post: 05-22-2008, 12:51 AM
  3. M2 ATX power supply wiring question... 3 terminals
    By Snortonnorton in forum Power Supplies
    Last Post: 07-25-2007, 08:25 PM
  4. Quick question about wiring
    By Kurack in forum Car Audio
    Last Post: 03-01-2007, 01:04 PM
  5. Replies: 6
    Last Post: 10-11-2006, 12:44 PM
