Results 1 to 8 of 8
Thread: Car computer software with command line interface to trigger actuator
    Jul 2011
    Thumbs up Car computer software with command line interface to trigger actuator
    Does anyone know of car computer software that has a command line interface that i can use to communicate with a circuit board that will trigger actuators to open doors/hood/trunk etc.
    For instance:
    Execute a command from command line to open driver door
    Thanks!
    Elsewhere
    You need hardware to do that.
    Fusion Brain, Phidgets, etc.
    How about the Wiki?
    Jan 2008
    i have to ask-- why do you want to do this from the command line? most carpc software is specifically focused at reducing driver distraction, and imo, using the comand line would go against that.
    Jul 2011
    Quote Originally Posted by DarquePervert View Post
    just so i am clear, I can access Fusion Brain, Phidgets, etc to trigger an actuator via windows command line?
    Quote Originally Posted by soundman98 View Post
    the computer in the car will be running a webserver. The actuators will be controlled by a web user. Click a link on the webpage, execute program via command line, door opens
    again, "Fusion Brain, Phidgets, etc " all have this capability, so it doesnt matter which i purchase?
    Raw Wave
    Nov 2009
    No doubt those (door) controls are paralleled with the manual switch?
    (I know this is a redundant reply. Not that I know all....)
    Elsewhere
    You will need to do some research about the command-line functionality. I honestly don't know.
    How about the Wiki?
    Nov 2004
    St Louis
    Quote Originally Posted by mistermister View Post
    For instance:
    Thanks!
    If you're asking if a front-end has the ability to execute commandline code, the Ride Runner front-End supports commandline interfaces. I have several buttons in my skins tied to command line code. Download the RR documentation and review the "skin commands.txt" sections on "RUN", "RUNW", "RUNQ", and "RUNQW".
    I believe the above items were mentioned because there are RR plugins supporting those devices, i.e., no need for a commandline interface.
    Good luck with your project.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i have 4 mjs usbio1's controlling various pumps and actuators. I believe that they can be controlled via command line. you should ask mitch... he's the main guy in charge of riderunner as well as the developer of the mjsio1's
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  1. Use temperature sensor to trigger RR command
    By deus ex machina in forum Road Runner
    Last Post: 10-23-2008, 06:38 AM
  2. CD to WAV ripping via command line
    By thekl0wn in forum Software & Software Development
    Last Post: 02-13-2008, 05:19 PM
  3. Run() with Command Line Parameters
    By theminor in forum SkinBedder
    Last Post: 04-28-2006, 08:11 AM
  4. Trigger script/command on resume from hibernate?
    By tejesh83 in forum Software & Software Development
    Last Post: 10-24-2003, 08:05 PM
  5. hmmm any command-line args for gps software?
    By Phat Justice in forum Software & Software Development
    Last Post: 12-01-2000, 04:05 AM
Tags for this Thread
