Can you possibly post a picture of the wires/switch internals, that would be most helpful in telling you exactly where to solder an external button.
Hello I am currently running an HP mini 210 as my Carputer. I wanted to ad an external power button similar to a post i saw on here done with a compaq laptop. The issue is that HP has this stupid power switch and i do not know where to solder my wired. I would really appreciate the help if anyone knows if it is possible to add an external power button to this mini. Please teach me....
Thank you
Mickey
Thank you Sean, attached are pictures of the entire motherboard and a close up of the power switch. Please let me know if this helps at all.
Thanks again.
From the looks of it, it looks like the switch still acts like a momentary switch so you just need to figure out which of the solder points are the positive and negative. If you have a Multimeter that would be your best bet on figuring out which solder point is what.
