Results 1 to 2 of 2
Thread: non-OBD2 gauges
    Jul 2011
    non-OBD2 gauges
    Hi all,
    Honestly, i have done lots of searching on google and this forum and im struggling to find information. I want to display oil pressure/temp for example, which cannot be taken from OBD2. If i get senders, what hardware and software do i need to accept the signals and interprate the sender information? fusion brain? How do i get this to display as well on one of the common front ends, or any program?
    Not sure where to start. My ECU is not standard and i run the tuning program to display all info that the ECU recieves (MAP, ign advance/retard, rpm, AFR, water temp, air temp etc), but oil temps and pressures are pretty important and i would like to display them without having any gauges hanging off my dash ( want to keep the interior clean).
    Aug 2011
    You might be **** out of luck if your car is old enough to not use OBD-II. The sending units are the easy part as they are probably included with most gauges. I searched around for a bit any everything I see that links with software seems to work only for OBD-II. Who did the tuning on your car? Maybe you want to ask the tuner if there is a program they can use to output to ODB-II for your purpose?
  1. Custom gauges for engine management software, non-OBD2
    By ddogg_777 in forum Software & Software Development
    Last Post: 02-17-2010, 03:27 PM
  2. Replies: 2
    Last Post: 02-23-2009, 04:49 PM
  3. car gauges
    By ampy549 in forum General MP3Car Discussion
    Last Post: 08-08-2006, 12:29 AM
  4. LCD on your gauges
    By zerosiggls in forum LCD/Display
    Last Post: 06-24-2004, 10:37 AM
  5. Hom many Gauges?
    By Dima in forum General MP3Car Discussion
    Last Post: 08-31-2001, 02:55 PM
