Results 1 to 2 of 2
Thread: Bondo?
    Jan 2008
    Wellsboro, Pennsylvania, United States
    Bondo?
    I ahve some work i need to do to smooth out some intereios pieces in my car. I was thinking bondo but wanted to check with you folks first see wat you think. It would be on plastic...needs to be something to put up with cold and some heat. Ideas?
    Jan 2008
    bondo would not work well. the plastic parts expand and contract at different rates then bondo does, so it would eventually crack.
    the best option is to locate the same type of plastic (there should be some markings on the back of the plastic pieces) and mold the new parts using that.
  1. Bondo-Glass or Normal Bondo Body Filler
    By adambeverage in forum Fabrication
    Last Post: 04-04-2010, 12:44 AM
  2. Bondo
    By NfErNo in forum Wiki Discussion Threads
    Last Post: 06-26-2007, 12:16 PM
  3. Bondo?
    By a-ten in forum Fabrication
    Last Post: 01-04-2007, 09:06 PM
  4. bondo
    By abervintageman4 in forum Fabrication
    Last Post: 07-08-2006, 09:42 AM
  5. for anyone who has done BONDO
    By ltrain1007 in forum LCD/Display
    Last Post: 07-20-2005, 03:25 PM
