Results 1 to 5 of 5
Thread: CarPC Sound Configuration Problems
    Nov 2011
    Israel
    Hello Everyone,
    I have CarPC almost 2 years in my Citroen Xsara, the system is working great and i get the best sound ever.
    But now i have a little problem with my new system, and i can't configure the sound.
    Old System:
    CPU: Atom 330 (on board)
    MB: Asus AT3N7A-I
    Mem: 2x2GB Patriot
    PSU: PW-200-M 200W
    Cam: 2xMicrosoft HD-5000 (front & rear)
    GPS: Holux GR-213-USB
    This system is connected from the onboard sound card to Hertz Energy Amplifier and to Rockford Subwoofer Amplifier.
    The sound application from Asus is very easy to use. I set the system for 5.1 Channels surround system and that is, when i play music the speakers playing and the sub PERFECT!
    New System:
    CPU: Intel Core i5 2400 3.1Ghz, s1155, 6MB, GPU Core
    MB: Gigabyte GA-H67N-USB3-B3
    Mem: 4x4GB G.Skill NT Dual Channel
    Other things are the same.
    I know i don't need 8GB in my CarPC but a buy them together.
    I connected my new system the same way it was connected with the old one, and i can't configure my sound system in the Sound Application.
    I set the system to work with 5.1 Channel and when i when i press on test button i hear my front, rear and sub speakers but when i press the play button
    on my Foobar or Centrafuse i hear sound only from the front speakers and that's all.
    I Don't know what is wrong... can someone please help me?
    THANKS!
    Constant Bitrate besjr69's Avatar
    Feb 2011
    Check to ensure the the "full range" setting is not checked. I'm at my work computer, but I had this problem and it was because I had rear and front set to full range.
    Nov 2011
    Israel
    Thanks besjr69.
    I tryed everything to make this work but still i stuck...
    Now i have my Subwoofer working but my rear speakers are not working,
    so all my sound go's to front speakers and the subwoofer.
    I attached the print screen from my sound settings...
    Please can someone can help me?
    Nov 2011
    Israel
    Problem Solved!
    After searching and searching i decided to re-install the sound card drivers.
    And then like a magic the problem solved.
    Thanks for trying to help besjr69.
    Low Bitrate agentq's Avatar
    Nov 2010
    Escondido, CA
    I will drop my 2cents here. I also had to use realtek sound and 5.1. To me the speaker fill was terrible, and I switched to SRS Audio Sandbox software to drive my audio. 5.1 channel would work fine for when there was 5.1 audio, but the SRS does an amazing job of up-mixing 2ch and pushing it to all the speakers and is very flexible and tweak-able unlike the realtek software.
  1. sound problems
    By Capri28 in forum Road Runner
    Last Post: 08-08-2007, 12:27 PM
  2. DVD sound problems
    By bigpimpn79 in forum StreetDeck
    Last Post: 03-25-2007, 03:17 PM
  3. Sound "clicking" problems with my new carpc
    By GibsonLP in forum Car Audio
    Last Post: 02-03-2007, 11:19 AM
  4. Replies: 3
    Last Post: 02-19-2005, 02:35 AM
  5. Sound configuration
    By Showmehow in forum Newbie
    Last Post: 09-05-2004, 01:56 PM
