Hello Everyone,
I have CarPC almost 2 years in my Citroen Xsara 2002 2.0L EXC, my battery is 72A and my Alternator is 60A.
Old System:
CPU: Atom 330 (on board)
MB: Asus AT3N7A-I
Mem: 2x2GB Patriot
PSU: PW-200-M 200W
Cam: 2xMicrosoft HD-5000 (front & rear)
GPS: Holux GR-213-USB
OBDII: ELM327
OS: Windows 7 Starter
This system is connected from the battery to Capacitor and from the Capacitor to Hertz Energy Amplifier.
From the amplifier to the Switch on a main console. The System is working perfect for and i use the CarPC for:
1) Music
2) GPS Navigation
3) DVR Recorder (minicam)
When i start to record a Video from my Front and Rear cameras the CPU jumped from 15% to 98% and my music start
to jump and PC start to freeze so i tried to disable one camera and the system start to work fine.
Also i can't record HD cause when i chose to record HD my CPU jumps to 100% and start to freeze.
So i decide its time to move to a new Hardware for my CarPC.
New System:
CPU: Intel Core i5 2400 3.1Ghz, s1155, 6MB, GPU Core
MB: Gigabyte GA-H67N-USB3-B3
Mem: 4GB DDR3 1066 G.Skill NT Dual Channel
Other things are the same.
I installed the new System in my Car and pressed the power switch and then i got the infinity power up and down loop.
I take a look on my Digital Capacitor i and found that when the computer is off i see 12.8V on my system when i start the ignition its 13.7V.
But when i Start my PC with ignition OFF the Capacitor jumps from 12.8V to 9.9V and when its reach the 9.9V the PC turns OFF and the ON.
When i start my ignition ON and start the Computer its jumps from 13.7V to 12.2V and stays the same and the computer works fine.
Sometimes when i start ignition ON and i press the Power button to start the PC nothing happens its looks like the system have Short circuit,
So i start to play with my Switch pressing its on and off and then i get PowerON.
p.s. have to say that old Atom system worked perfectly without any ignition ON.
Can someone help me to solve this problem? or this system can't work without ignition?
Have can i fix this Short circuit when i start the engine, or should i change the PSU?
Should i connect the CarPC directly to a battery for leave it connected to the amplifier?
And can some help me to decide what os to install Win7 Pro x86 or x64?
I know a lot of questions but i really need help.
Thanks in advance for any kind of help!
