Results 1 to 6 of 6
Thread: recommendations on power supplies that WILL not drain the battery
    Apr 2009
    Round Rock, Texas, United States
    Howdy, I'm looking to put a car pc into a 2008 WRX. My main sticking point right now is that it has an Odyssey mini-battery(basically for a motorcycle/ATV) and they have limited Cranking amps compared to a full size battery.
    I just want to make sure that however It's powered, that there is no chance that it will draw down the battery when the alternator is not running. I had always planned to do this, then realized that in going to the race battery, it may now be more complicated.
    I plan to add a touch screen in the factory radio location, and a Small Form factor PC. Probably a Shuttle XPC with the case cut in half.
    The PC itself will be pretty stripped down, M/B, SSD, no Optical drive, but I may be adding an AMP of some sort to power, likely, just the front two speakers. I'll likely remove the rears. I may try to do some sort of mini set of removable speakers, and remove all the speakers, as the type of racing I do, rule number one is take as much weight out of the car as is allowed, so I may not even need an Amp. I'm not an audio connoisseur.
    The PC will run Data Acquisition software of some sort, OBD2 info for digital gauges, and may even run cameras.
    Any info or opinions would be greatly appreciated.
    08' WRX - lightly prepared for D-stock autocross
    1994 BMW M3/25is - Heavily prepared for SM class autocross
    OBD1 :( no carputer fo the Bimmer
    Jun 2010
    Vancouver, Washington, United States
    The weight savings from the small battery seems counterproductive to the functionality you want from the stuff you are putting in. Really, if you are stripping things down to that point you don't want to put in an amp, speakers, AC, passenger seats, radio or anything that isn't necessary for driving the vehicle.
    (edit: rereading that, it sounds like I'm being a jerk. Sorry. What I mean to say is, putting a small battery in there should be one of the last options to cut weight. If the car is a daily driver and not a trailer queen between races, I'd say that shouldn't even be an option)
    With the stuff you want, really, just put a standard battery in there. The 10 lbs isn't going to make any noticeable difference, I assure you.
    That being said, Carnetix power supplies, for example have voltage monitoring and auto-shut off. On some models you can adjust this so you can be sure to cut power before it drains the battery past the point of being able to start the car.
    Elsewhere
    If you're considering a Shuttle unit, most of them use standard ATX power supplies. An M-series, Opus or DSATX will all shut off all power to the PC to prevent battery drain, as well.
    I agree that a minimalist battery is not what you want if you're adding electronic equipment to a vehicle.
    How about the Wiki?
    FLAC -zip-'s Avatar
    Ontario/Canada
    1. Make sure its bolted down agressively - have a look at metal strapping. Not sure if you get inspected or not
    2. Forget running cameras from the PC, us a GoPro or Contour if you are considering it
    3. Whatever ODBII software/reader you use make sure the maximum PIDS are supported for your vehicle
    4. Have a swtich between the battery and power supply, that way its impossible to drain the battery no matter what type of power supply you use. Set up the power supply to start shut down sequence as soon as the key is turned off.
    5. I race with air conditioning on, sounds like you are pretty hard core so if you run with it off make sure the PC is vented to the max with fans
    Sound Stage
    Eclipse|MTX|Infinity
    Jan 2008
    Quote Originally Posted by -zip- View Post
    it is better to use a relay to handle the high draw then a switch-- the switches that can handle that amount of power(10-25A) are less attractive and more expensive then a cheap switch/relay combo.
    Raw Wave
    Nov 2009
    x2.
    I never like running more than a few Amps (maybe up to 10A in a 16A switch). Plus there are cheaper and more (and smaller) switch options if it merely has to carry ~250mA to maybe 2A for a BIG 250A relay. And all your heavier power wiring stays remote and is probably much shorter.
    The alternator's charge lamp could control a relay that disconnects the load from the battery when not charging, but if needing a supply, the above mentioned 12V-automotive supplies offer far more features (like delayed off or low-volts shutdown).
  1. How to meter power drain? (dead battery issue)
    By XxAndyxX in forum General MP3Car Discussion
    Last Post: 05-20-2006, 01:43 PM
  2. Replies: 3
    Last Post: 08-04-2004, 05:52 AM
  3. Power drain on battery...
    By Ormo in forum Power Supplies
    Last Post: 06-23-2004, 01:40 AM
  4. S1 Standby Power Consumption Drain Battery?
    By Grayscale in forum General Hardware Discussion
    Last Post: 06-16-2004, 03:30 PM
  5. Replies: 1
    Last Post: 02-06-2004, 05:44 PM
