Results 11 to 20 of 21
Thread: Please Critique My Idea
  1. #11
    May 2005
    Rochester, NH
    UG seriously, we are going to do this again? 2.5" HD typically are rated for higher shock than 3.5" drives. AND so nobody can flame me... here are two PDF's from Western Digital proving it. First is 3.5" WD Caviar Blue, Second is 2.5" WD Scorpio Blue. Both are of the same "series" AKA BLUE but 2.5's are scorpio and 3.5's caviar... I digress.
    3.5" 30 - 65 OPERATING Gs or 300 - 350 non operating
    2.5" 350 - 400 OPERATING Gs or 900 - 1000 non operating
    BIG difference so it can't be said that caviar and scorpio are apples/oranges in series'.
    http://www.wdc.com/wdproducts/librar...879-701277.pdf
    http://www.wdc.com/wdproducts/librar...879-701278.pdf
  2. #12
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by dmcdlrn View Post
    Sure, How many Gs of shock are the driver and car rated for? Book specs are great, they are not proof one is better than the other in a car. Not disputing your numbers or the factory specs at all.
    If you have been in any other HD threads you will have read my personal history with wrecked cars, bent frames and a desktop drive that is still functioning after being in use when the frames (boxed ladder type and yes, plural) bent.
    Deal with it.
    A far more likely cause of HD failure in a car regardless of form factor is poorly regulated p0wer. Nope, I can't 'prove' it or change your mind. But you cannot disprove it either.
    Did you enjoy your spoon?
    TruckinMP3
    Read the FAQ!
  3. #13
    May 2005
    Rochester, NH
    I never disputed if a 3.5 would handle the g's of the road or an accident. Surely the hard drive is rated for more g's than a human body. I simply pointed out my statement was in fact FACT.
    A 60 mph crash with a stationary object will have around 30g's (assuming .1 second deceleration time)... at that point the human is not feeling well if anything at all and even the 3.5" hd is still within spec. So, you are correct; the only proven reason to go with a 2.5 over 3.5 would be size and power consumption. But, if I had a 3.5" drive or a 2.5" drive to choose from all things equal... I would take the 2.5" because it will by definition handle the stress of the road better in edition to its reduced size and electrical consumption and increased speed. Would I pay more for it? No.
    The fact that you have wrecked multiple cars(as I gather from your semi cryptic statement) with a hard drive on board proves little other than you are lucky and likely either a poor driver or an odd combination of lucky and unlucky at the same time. Certainly not dissing your driving skills, but without further details I have little to go on.
    There is a reason IBM and other manufacturers put effort into parking the heads on their hard drives when a laptop detects it is free falling. Probably not because their research said you were guaranteed to loose the hard drive but rather it wasn't worth the risk.
    Not sure about the spoon... some weird matrix joke or are you trying to be rude? Either way you can keep it.
  4. #14
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    If you two want to argue about the merits of 2.5 vs 3.5 drives, go ahead, however it is out of scope for the topic of this thread, so you might do well to create a new thread to do so rather than clutter up this one. This guy is using a laptop, he's kinda limited to a laptop drive, regardless of which is better.
    RevFE
    My Shop
  5. #15
    Jun 2002
    Colorado
    Quote Originally Posted by matthewprenger View Post
    Welp. Just bought the screen. Will post back on how it looks.
    Well, how does it look?
    TruckinMP3
    Read the FAQ!
  6. #16
    Aug 2011
    Quote Originally Posted by sargeants
    How do you plan on powering the laptop?
    I have an Igo Juice 70 with a car adapter plug on it.
    Turning it on and off?
    This is one of the things i have been thinking about. I plan on soldering a wire to the power button on the laptop. What I cant decide on is if I should just put a button on the end of it or find a way to use a relay and have it activate for just a second.
    How does the laptop handle outputting video externally all the time?
    It has a VGA port on the side. And with the ATI graphics manager I can tweak the size down to what I want.
    What are you planning on doing for a frontend?
    Centrafuse
    Are you going straight from the laptop into an amp, or keeping the deck you have and using the aux in?
    From the laptop to a Clarion EQS-746 EQ then to the amps.
    Quote Originally Posted by malcom2073
    and if you're running CF, then definitely a laptop with a better video processor inside, otherwise you may experience lag issues.
    Ive tested Centrafuse over the past couple of days on that laptop and it seems to work fine without any lag.
    Quote Originally Posted by TruckinMP3
    The screen looks great. I love the LED backlighting on it. It looks like it should do fairly well in sunlight. I will probably hold off on installing the anti-glare shield until I test it and see how it does without it.
  7. #17
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Really? Athlon were fast little buggers. I remember recording over 10 tracks at a time on an Athlon 1800+ back in the day. http://www.cpubenchmark.net/cpu_look...ual-Core+TK-53 puts it above all Atom processors and I know lots of people run them around here.
    Need a Sandy Bridge-E 6-core to run CF with any decent speed. Oh, and the fastest SSD you can buy.
    Former author of LinuxICE, nghost.
    Current author of nobdy.
  8. #18
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
  9. #19
    May 2005
    Rochester, NH
    Quote Originally Posted by tripzero View Post
    lol, That bad? I've never run CF other than on my core2 desktop for trial. My atom runs RR & dashcommand just fine. I have heard that certain skins will kill an atom in RR though.
    There is a circuit you can build here: Laptop Auto Power-On / Turn-On Module
    You could get a standalone shutdown controller like this one: http://store.mp3car.com/Micro_Shutdo..._p/pwr-007.htm
    Shutdown controllers are good safe option though as they usually have fail safe built in so that it will kill power even if the computer hangs. This will keep your battery from A) draining and B) deep cycling.
  10. #20
    Aug 2011
    Just ordered the microshutdown controller from the mp3car store, thanks for the advice
  1. Please Critique my Car PC system
    By jdotp17 in forum General MP3Car Discussion
    Last Post: 10-02-2010, 11:40 AM
  2. Another critique?
    By RavageiWISE in forum Newbie
    Last Post: 01-21-2007, 10:23 PM
  3. Specs and critique please
    By Lord_Pall in forum Newbie
    Last Post: 11-24-2004, 10:31 PM
  4. Yes another critique
    By SRT4 in forum Newbie
    Last Post: 08-28-2004, 12:18 PM
  5. Critique my plan
    By Kidane in forum Newbie
    Last Post: 08-01-2004, 12:46 PM
