Results 1 to 6 of 6
Thread: 2003 Infiniti G35 CarPC and Sounds System Install Questions - Hardware
    Feb 2012
    Canada, AB
    Lightbulb 2003 Infiniti G35 CarPC and Sounds System Install Questions - Hardware
    Hey everyone,
    I have been reading this forum for a few months now and finally decided that the carPC would be the best bet for my new sound system. I have selected (mostly) all the hardware for the install but I have a few things I still need to clarify.
    1) I opted for the M4 250W power supply but will it fit in the case I selected? If it is to large, which is what i'm thinking what are my options (separate case)?
    2) What is the best option for integrating the AM/FM from the car into the computer?
    3) Other than basic wires, is there anything I am forgetting off the top of your heads?
    Thanks so much for all the help. And I will make sure to document the install =D I included my parts list below.
    Cheers, Geoff
    Computer
    Motherboard: ASUS F1A75-I Deluxe FM1 AMD A75 (Hudson D3) HDMI SATA 6Gb/s USB 3.0 Mini ITX AMD Motherboard $149.99
    Processor: AMD A8-3870K Unlocked Llano 3.0GHz Socket FM1 100W Quad-Core Desktop APU with DirectX 11 Graphic AMD Radeon HD 6550D $144.99
    RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBXL $59.99
    Hard Drive: OCZ Agility 3 AGT3-25SAT3-120G 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD) $149.99
    Power Supply: M4-ATX 250W Intelligent DC-DC PSU $77.95
    Case: 5677 Mini-ITX Case Without PSU w/ Quick Release + Hayco Grommet $84.99
    Monitor: Lilliput 7" SKD Open Frame Touch Screen VGA Monitor with HDMI, DVI Input $184.95
    Double Din Kit: 2003-2004 Infiniti G35 Double Din Kit (Willow) w/ A/C Control $345.00
    Accessories
    Microphone: Andrea Electronics Superbeam Array Microphone Bundle SUMA $39.95
    GPS: BU-353 Waterproof USB GPS Receiver $34.95
    Relay: http://denkovi.com/product/41/usb-ei...ation-12v.html $46.50
    AM/FM: Unknown
    Sound System
    Front Speakers: Kicker KS6.2 $179.99
    Rear Speakers: Kicker KS693 $129.99
    Subs: JL Audio 12W3v3-2 $279.99 $559.80
    Amps: JL Audio Slash v2 Series 1000/1v2 $749.99
    Sound Ordnance™ M-4075 $149.99
    Capacitor: Undecided
    Feb 2012
    Canada, AB
    The table didn't work ill try again later today :-)
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Welcome to MP3car!
    I do not run am/fm & use a laptop so I will leave your first to questions for others. My suggestion is to run a 4 or 8 guage fused power wire directly from the battery into the pass. comp. and connect it to a fused distro block. That way, as you decide to add "more" the power is already there in ample quantity.
    Jan 2008
    that psu won't fit in that case-- it's just too wide. i believe the m2 should work for that hardware.
    as far as the capacitor-- not needed. if you have dimming issues, then that means you need to do some work on the power side of the system-- like the big-3 upgrade, different alternators, etc.
    Feb 2012
    Canada, AB
    Running over the specs though for the system. It requires at least 200W especially for the quad core processor. Would an external case be an option? Is there one made for the M4? You don't think the drain of the first amp and the second amp at 1000WRMS would be an issue? I have a great alternator and a brand new yellow top but I don't want a strain on anything I have aftermarket gauges and a tuned ecm plus other electronics not listed. For $100 though it wouldn't really hurt :-D
    Feb 2012
    Canada, AB
    Just confirmed, the cpu wastes over 160W of power. Still nothing on am/fm for cars haha :S
  1. MP3Car Infill G4 install in a 2003 Infiniti G35
    By god_of_cpu in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 02-26-2012, 04:30 PM
  2. 2003 Chevy Malibu CarPC Install
    By craig131 in forum Worklogs
    Last Post: 01-16-2010, 06:15 PM
  3. MP3Car Infill G4 install in a 2003 Infiniti G35 (Moved Threads)
    By voidunknown in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 04-11-2007, 12:37 AM
  4. 2003 BMW Install - general questions
    By daregone in forum Newbie
    Last Post: 10-26-2006, 02:25 AM
  5. 2003 Impreza WRX - my first CarPC install
    By TherealV in forum Show off your project
    Last Post: 07-21-2006, 08:25 PM
