it depends on what kind of problems they are talking about. assuming whatever you downgrade it meets the requirements of the device, there is no issue there. the only issue i can possibly see is that cutting the cable adds a failure point-- if one of the bolts were to come loose, etc.
yes. it should always be at least as large, if not larger then the power input wire.
