Results 1 to 3 of 3
Thread: Computer controlled lights
    Apr 2012
    I am new here, so thanks to anyone who helps me out. I have been researching this for a while and am I little unsure how to proceed.
    My ultimate goal is this:
    Have a touchscreen mounted in my car with a custom GUI that I will design to control lights inside and outside the car
    There are a few ways to do this that I am aware of.
    1. Put a computer in the car, write an application that controls USB relays. (seems like overkill)
    2. Put in a custom android device that runs a custom app that in turn controls an Arduino with relays attached (seems overly complicated)
    I can't just use an Arduino because that is not powerful enough to support a large (above 5") touchscreen.
    Has anon here used android to control some relays or have any other way of computerizing relays?
    Thanks!
    Newbie Gonkulor's Avatar
    Mar 2012
    Bayview, Idaho
    here is another option
    Check this out. 24 channel USB controlled. I'm planning to use it in my build. It's a DIY, or you can have it assembled and tested, but I'm in communication with the inventor who I'm having write extra firmware to control my exterior lights. It's an RGB LED controller but it might work for you? I also don't want to appear as I'm endorsing this unit. All I can say is that I'm having a heck of a time finding a controller for my project and this appears to be the only reasonably priced solution I have found.
    Good Luck
    Gonk
    MySQL Error
    Oct 2004
    look at this...
    http://store.mp3car.com/USB_LED_1_RG..._p/com-143.htm
    its only 3 channel, ie for R, G , B
    but has a developer dll, and already has full riderunner support
    and yes, you could use more than 1 at a time
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  1. Computer Controlled Guages
    By AznRida in forum Hardware Development
    Last Post: 09-30-2009, 10:00 AM
  2. Computer-controlled backlight?
    By NSFW in forum LCD/Display
    Last Post: 01-05-2009, 11:49 AM
  3. Computer controlled switches (or Relays)
    By MarkJoel60 in forum Newbie
    Last Post: 08-04-2008, 12:30 PM
  4. 2nd battery + computer controlled lighting
    By jparks27 in forum Show off your project
    Last Post: 06-02-2006, 08:52 PM
  5. FS: computer controlled 12 volt 6 channel equilizer
    By WhiteRabbit in forum Classified Archive
    Last Post: 03-23-2005, 01:40 AM
Tags for this Thread
