the easiest way to test it is to use a computer power supply. disconnect the 20-pin connector near the top of that picture to the left of the fan, and plug in the normal pc power supply there. then you just need to short the power button pins on the board. anything from a old computer power button to a butter knife will work for this.
this method does not test the dc-dc power supply, but that is easy enough to test within the car. the power supply is fused, and any wires you run to it should be fused, so a fire should not happen unless you bypassed the fuses or used too large of a rating. i believe the m2 has a 15A fuse on-board, so as close to that as you can find on your battery fuse would be best.
no big deal. these cases are kind of generic, so to not have those connected just means that there might not have been a spot for it on that motherboard, or it was not needed in the previous owners build.
forget those for now. just connect directly to those ports.
those are GLI's, or Ground Loop Isolator, and i only recommend them only after you have issues with rpm whine, or constant whine in the audio signal. if you don't have any issues like these, these are a unnecessary layer to fix a problem that doesn't exist-- hence why i only recommend messing with them only after you have the problem..
those are power filters from lilliput monitors--2 of them, from 2 different screens. i haven't been convinced that they help anything, but at the same time, i don't think they hurt anything either.. those are meant to be installed on the power input lead going to the screen. do you need them? the best answer i've heard is if your powering the screen via the carpc's dc-dc, then no. but if your powering the screen from car power, then yes.
are you familiar with what that is? it's a obd port reader-- considering you've got a 96+ tuned car(at least it looks that way, if you run a stand alone engine management, then it really doesn't matter), it might be worth keeping around. at the very least, you can check and clear codes with it..
to test the power supply, the easiest way is to pop your hood.
i can never remember if it is the red or the white that is the trigger wire, but i know that both are positive wires. one requires a constant +12v, the other is the trigger wire to turn it on- the acc wire like on a aftermarket amp.
the black wire is your ground.
to test it off a car battery, just connect the red and white to the positive terminal, and the black to the negative terminal.
LinkBack URL
About LinkBacks
