Results 1 to 3 of 3
Thread: help with Installing galaxy tab on my car
    Jul 2012
    Hi,
    I saw many people are installing tablets on there car on youtube but they don't show how,
    here is my idea I will take of my stereo and cables will be left there right ?
    1- So how can I connect those cables to my tablet to act as stereo or is there any better idea ?
    2- How can I make my tablet connected to the car power or does the stereo cables do that to ?
    (My car is sonata 2013)
    Regards
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Moved to newbie section.
    Sounds like you have a lot of reading and research to do.
    Tidder
    Try RevFE
    Jul 2010
    Many get whatever car adapter can be used to power/charge the tablet in the car. Just make sure the adapter supplies enough voltage, or else you won't be charging while using it and it will slowly drain. To hook the audio up, you will need an amp. The tablet should have a headphone slot, so you'll need an 1/8" to rca (and then split if you need more than 2 channels). Hook the rca's into the amp, then using speaker wire coming from the amp, wire the correct f/r l/r to an aftermarket wiring harness to the correct f/r l/r wires. Using an aftermarket harness you won't have to cut into factory wires. You will also need to supply power/ground/switched power to the amp.
    Current Worklog: TBA - '05 Rav4 (Mobo Dead).
    www.rav4world.com - Forums for Rav4 owners
    www.flavorfeasts.com - Cooking website/forums
    -Basic forums live atm, come contribute!
  1. iPad or Galaxy Tab?
    By DonMegel in forum General Hardware Discussion
    Last Post: 06-06-2012, 02:47 PM
  2. Looking for this for Galaxy Tab 10.1
    By Lando in forum Android Tablet
    Last Post: 02-27-2012, 01:40 AM
  3. Galaxy Tab in 06 Civic Si
    By mich1248 in forum Android Tablet
    Last Post: 08-10-2011, 01:52 PM
  4. Galaxy Tab
    By ninjaspy in forum Newbie
    Last Post: 05-02-2011, 03:50 PM
  5. Mario Galaxy 2
    By chunkyks in forum Off Topic
    Last Post: 06-08-2010, 01:08 PM
