Results 1 to 2 of 2
Thread: Front factory speakers crackling after...
    Oct 2012
    i have put some speakers in the back of my car today,
    i just cut the front speaker wires near the car cd player, and used butt connectors to link both the front and my new speakers together, the only problem is my 2 front factory speakers are crackling if it goes a little louder.
    this was sort of hard to explain, anyone out there to help, or explain brielfy how to set up new car speakers to my cd player + where the wires go etc instead of fusing factory wires together :s
    Jan 2008
    it's probably too low of a resistance. normally, car speakers are 4 ohm, so it would be 2 ohms of resistance per channel, which might be too low for your deck, causing the 'crackling.
    it sounds like you wired them like the image on the right, i suggest you change it to be wired like the image on the left.
    this will reduce the overall loudness of the system, but will work reliably. the only other solution is to get a deck with 4 outputs, and connect each speaker individually.
  1. Crackling Sound From Speakers
    By danmn1313 in forum Car Audio
    Last Post: 08-20-2010, 07:19 PM
  2. Static, Crackling speakers
    By RanDJ8487 in forum Car Audio
    Last Post: 07-29-2008, 04:48 PM
  3. Major crackling speakers, tried everything!
    By joe588 in forum Car Audio
    Last Post: 10-18-2006, 07:34 PM
  4. Crackling sound thru car speakers!WHATS WRONG!!?!?
    By ironic in forum General Hardware Discussion
    Last Post: 08-06-2006, 06:34 PM
