Results 1 to 4 of 4
Thread: Amp Mounting
    Jan 2008
    Wellsboro, Pennsylvania, United States
    Amp Mounting
    Has anyone ever munted an amp to the ceiling of the car? Any heat issues? I am just thinking of a way to make the install more interesting
    Mar 2011
    Ohio
    I didn't attach an amp to the ceiling of the inside of the car. Years ago (1993-1994) I had an 88' Honda Accord Coupe. In the area between the speakers in the rear deck I mounted an amplifier upside-down. I believe it had a built in fan. The car looked very factory, you had to crouch down and look up to see the amp if the trunk was open. In those days I didn't even consider a car PC. I was using an external Pioneer 6 Disc CD changer. It was mounted behind a spot under the radio that was dedicated for storing cassettes. I could remove the plastic cassette holder and even change CD magazines while driving. It was an RF modulated model, but I found the audio out from the CD changer's RF box, and wired it to a little toggle switch on the front of my cassette radio. I also cut the traces on the volume control in the radio so that I could select from two sources. Put the switch up, and it was normal, play cassettes and AM/FM. Put the switch down, and it was the CD changer. Wow, was I cool back then! LOL!
    Jan 2012
    I got creative and mounted mine under the back seat of my truck.
    Low Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, The Netherlands
    mounting an amp upside down isnt going to be an issue , as long as heat can escape to somewhere
    View my worklog here
  1. What is the name of this mounting?
    By phenaly in forum LCD/Display
    Last Post: 11-06-2009, 01:37 PM
  2. OHV mounting
    By AndyLcgy in forum General Hardware Discussion
    Last Post: 11-25-2007, 11:42 AM
  3. Mounting the GPS
    By dbzeag in forum GPS
    Last Post: 02-22-2006, 01:02 PM
  4. HDD mounting?
    By DorkVonWaterfal in forum Newbie
    Last Post: 04-04-2005, 11:21 AM
  5. Lcd mounting
    By Talldude4evr in forum General Hardware Discussion
    Last Post: 06-16-2003, 06:32 AM
