Results 1 to 10 of 14
Like Tree1Likes
Thread: Kill Switch...because I believe in over kill.
    Jan 2008
    Wellsboro, Pennsylvania, United States
    I am looking for a switch that I can put inline on my 2 gauge power line. has anyone every done it?
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I never have, but I just seen a car battery cutoff switch at Harbor Freight that would do the job.
    Sent from my SCH-I535 using Tapatalk 2
    Oct 2004
    NY
    use a circuit breaker, the resettable kind... you can trip it at any time to open the circuit, like a switch. this is the most compact way to switch this, and it also adds the necessary protection that you would have otherwise had to use a big fuse holder anyway
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Big rigs and heavy equipment use a master disconnect switch. I think you will need something like that for that 2 gauge wire. SNO
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by turbocad6 View Post
    I have one of these up under the fender. It's not easy to get to per say, but it works
    GizmoQ likes this.
    Live mp3Car Facebook Chat
    Raw Wave
    Nov 2009
    Ah - a favorite topic... of mine.
    Do you mean kill switch, or isolation switch? The two are very different and cannot be combined (safely) with a single switch.
    I assume you mean an isolation switch.
    The best is a switch in the battery's -ve/ GND lead. That's best because it can be located anywhere on/in the vehicle without safety issues if the battery cable gets pinched and shorts to chassis or the bonnet shorts to the battery +ve terminal. (That's an important issue for competitive vehicles that require isolation switches in case of accident. Most are required to be cabin mounted in reach of the driver, and some require an additional switch at one rear corner of the vehicle. And I note with amusement that few prohibit +ve isolation LOL!)
    For non-competition purposes there are more options. Because the starter or alternator an other loads may be acceptably left connected, a smaller switch can be used in whatever +ve feeds are desired.
    The -ve/ground version is generally only suitable to switch ALL -ve/gnds from in the battery -ve terminal. It hence has to be rated for starter motor currents plus other loads. (You never want to break just one ground in a multi-grounded system - eg, battery -ve to engine to body, amplifier of HU power GND, CPU GND etc. Alternate ground paths with blow circuits, burn cables & tracks, fuse throttle cables, etc.)
    For +ve switches, I like the thought of the circuit-breaker types.
    For GND and competition use, it's usually the plain $20 isolator switch.
    Now, as for kill switches....
    Jan 2008
    I would like to have the ability to shut of the power to that line completely is what I am looking to do
    Raw Wave
    Nov 2009
    Ok, an isolation switch, for specific loads, hence +12V switching.
    There are lot to choose from including those pictured above. Even relays could be used (especially for automated or timed or low-voltage-cutout disconnection).
    A common type of switch used for competitions is:
    .. but many variants exist.
    The main thing is that the switch has a current rating higher than the fuse your are using for that line (I assume 150A - 200A for 2G?).
    And beware peak current ratings as opposed to constant current capability.
    Mar 2006
    Colorado, but Canadian!
    You don't want to put a switch that you physically flip directly in line with the main power. That is just bad mojo waiting to go wrong.
    Put a switch that controls the coil of a relay. The extra 20mA of current draw is well worth the protection of the switch. And if you are planning on using the switch as a plug/unplug, then you could wire it so that the normally closed powers your system and when you flick the switch it disconnects and the relay conducts. That would be the best in terms of power saving, but backwards from what people would expect.
    This also gives you the ability to use a good high quality relay and and cheap crappy switch. The benefit is that the switch can be a very small but awesome looking switch instead of one of the very few able to switch the power required for your whole system.
    1.9in x 2.9in -- 47mm x 73mm
    Raw Wave
    Nov 2009
    Not that I disagree - I too usually always suggest relays hence eliminating big switches and minimising voltage drops as well as have a large selection of switches, and inputs (FusionBrains, PCs etc).
    IMO it comes down to the application. Presumably it's for audio or other accessories, a suitable relay/contactor.is appropriate (no matter how it is controlled).
    But if to isolate a main supply (as in competition) or to disconnect something normally powered, then a switch is probably more appropriate - eg, manual switch(es) to isolate parallel batteries instead of battery isolator relays.
    (Al I know is it's a 2G cable, not it's function.)
    But a switch is advised (read: is used except in complex redundant relay implementations) where relay opening or failure is critical (eg, main power; maybe beams).
    If it's audio that does not have to be isolated frequently, then a switch. If power is only required when in operation, then a relay.
    FYI - relays can bounce. Hence not used for "competitive" main-power isolation except when considered reliable enough; usually requiring redundancy and known-spec components (G-forces etc).
  1. immobilizer or kill switch
    By 4thephil in forum General Hardware Discussion
    Last Post: 12-27-2008, 04:05 PM
  2. question about M2-atx kill switch
    By Sonicxtacy02 in forum Power Supplies
    Last Post: 04-19-2006, 01:07 PM
  3. Opus Kill Switch
    By ukchris in forum Power Supplies
    Last Post: 10-27-2005, 04:07 PM
  4. Kill/'Live??' switch?
    By GreenBeast in forum Power Supplies
    Last Post: 07-11-2005, 01:47 PM
  5. Opus kill switch
    By naveedh in forum Power Supplies
    Last Post: 12-23-2004, 09:19 PM
