Results 1 to 2 of 2
Thread: Please help on my new High end System!
    Sep 2011
    Hello so im getting what i consider IMO a high end system based on what i had before at least and have couple questions if yall could help please (sorry if some of them are retarded)
    Car: 2009 Mitsubishi Lancer ES
    System:
    AMPS: Alpine MRX-F65 (highs) and Alpine MRX-M110 (bass)
    SUBS: JL Audio 10W3v3-4 (in Parallel for 2omhs) (x2)
    SPEAKERS: Polk Audio MM6501. (front and back)
    DECK: Kenwood KDC-X996
    IPAD: iPad Mini with a float mount from SoundMan
    Wires: 0 Gauge from knukonceptz
    RCA: from knukonceptz
    Question:
    -I canít seem to find anywhere that tell me how to run my wires for best quality sound (for example should i ran my power from the driver side to the trunk and the speaker and RCA wires on the passenger?)
    -Also i think ill go with SecondSkin from my deadening, but im confused what products i should get and what works best in your opinion like should i lay vibration damper pro and then some CCF on top or something like that?
    -how close should i place my Power Distributor Block to my amps (i want to know in order to know how much wire to buy)
    -and last question is should i get some EQ, Line Drivers and Crossovers from AudioControl? or is this a waste of money and over kill?
    Thank you so so so much in advance for those of you taking the time to answer some question i really appreciate it
    Elsewhere
    Quote Originally Posted by nickflow View Post
    Question:
    Answer...
    The simplest is to run power wires along whatever side of the car the battery is on.
    Run the audio lines down the other side.
    That's really going to depend on where everything is going to be mounted.
    Again, that's up to you.
    I use a Three.1 (now the Four.1), but I also don't use a headunit, either.
    Granted, I'm very pleased w/ the AudioControl EQ for what it does in my system.
    I can't say if it would add to your setup, though.
    How about the Wiki?
  1. Replies: 3
    Last Post: 02-05-2010, 09:35 AM
  2. Winamp for High-End system
    By leonm12 in forum Software & Software Development
    Last Post: 04-17-2009, 08:17 AM
  3. System Help (High End Audio System)
    By Ianaconi in forum Car Audio
    Last Post: 05-24-2008, 07:48 AM
  4. HELP high output 5.1 system w/o HU
    By PT0NE in forum Car Audio
    Last Post: 07-19-2007, 10:12 PM
  5. Replies: 85
    Last Post: 07-09-2007, 05:44 AM
