Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Thread: NEWB question. Anyone familiar with GMLAN. Please help!
    Jul 2013
    I need to know if there is anyone on here that is experienced with the BCM GMLAN system from 08/09 Pontiac G8. There is $$$$ in it if you are and know how to do some tricky stuff. I need my 09 G8 HVAC/RADIO to operate completely standalone. No steering wheel controls, no input from anything other than BCM and power. Is it possible? Can it be done? What do you think...
    The radio/HVAC system are going into a 69 GTO, with teh rest of the dash. The only electronics I want from the G8 in the dash are the HVAC/ and radio. Everything else is out.
    I know it will be a lot of programming, anyone up to it?... If you think you can do it PM me. I am new to all of the LAN systems and learning but I need someone with real experience to help get this thing rolling.
    -Shep
    Dec 2010
    I'm putting an 04 GTO dash into a 72 LeMans, more or less the same as your Goat, but I'm doing a carpc in place of the radio. I haven't started messing with it that far yet(I need to get some more parts). Let me know how you make out
    May 2012
    Grandville, MI
    A problem you will run into with this is that your radio ties into the can bus and will not work without it. It will pull the VIN from the vehicle to verify it isn't stolen and will also require the CAN bus to communicate some functions. The courtesy tones of most newer GM vehicles also go through this. The ONLY way you will be able to accomplish this is to have a fake BCM in your vehicle to communicate to the radio. You may be able to build one with an Arduino board but it will take some trial and error and you will need to be able to pull the communications between the radio and the BCM before it was removed to identify what is being communicated.
    If you do this yourself you can expect a lot of work and a few trips to the dealer to unlock your radio (At $30 a pop if your lucky). If you plan on having someone else doing this for you expect to pay thousands. But in the end why? It would be much cheaper to build a CarPC into that vehicle and have much more power.
    Jul 2013
    I was going to run the BCM from the vehicle that the radio came from. I will use as much as I need to in order to make this work. What I am trying to figure out is what exactly will that be. I also am trying to find out if there is a way for someone to program the BCM and modules for the radio and HVAC to enable this to happen. Is it possible and who can do it. I looked at CarPCs but the ones I have seen look like they tie into the BCM anyway.
    Quote Originally Posted by redheadedrod View Post
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Correct me if I am wrong but that 69 gto would have cable controlled heating/dampening doors. I really think you are beating a dead horse trying to just use bmc from computer controlled car into a non-obd1 or 2. I think you would be better off with carputer and a good screen. HD radio maybe XM if you want, plus whatever your music collection is, use phidgets/fusion brain/audrino with servo's, relays to control heating/air. Plus you could then use sensors to gather more info related to car monitoring. A good front-end to control all that and your good to go. I have not seen any carpc's that connect to bcm, only via obd2 port and thats really just for monitoring engine info. Just my 2 cents SNO
    Jul 2013
    The original 69 GTO had a HVAC system that was controlled by cables and vaccum. It has been removed and the plan is to replace it with the entire HVAC system from the G8, all of it. Both the pass compartment and engine compartment halves, the compressor setup on the engine itself, and of course the HVAC controls from the radio. The look of the G8 radio is one of the things that drew me to the interior. If I wasnt soo new to all of this CARPC stuff I would be down for doing it. I just want to keep a touch screen, the stock look, some of the stock functions, and the HVAC controls. I dont know anything about the CARPC stuff. I wouldnt even know where to start. I am doing lots of reading but I would rather buy something that is plug and play even if I had to pay someone to build it. Between the rest of the car needing finished I dont want to spend the weeks/months it would take me to try to setup the CARPC.
    Nov 2012
    You will have to reprogram the radio via TECH II to change the vin ID recognition.
    That will have to be accomplished to get it to even work as there is a "handshake/verification" done by the onboard computer via the lan.
    Not very hard, but you do need access to a TECH II unit.
    As for standalone operation, not very easy as the 69 is computer less.
    The earlier units could be "defeated" into stand alone operation by removing the identifier ROM.
    http://www.automotiveforums.com/t899...mp3_cd_hu.html
    Jul 2013
    heavymetals, that is the kind of information I am looking for. A what do I need to do, what parts do I need, who can do it, who wants to do it for the extra cash. Kind of thing. I hate to take the easy way out of this but between being in Afghanistan for 5 more months, having to put the ENTIRE car together when I get back, having to fab up the turbo system and design my own fuel system, and having to do all of this before I start school full time.... I just need this one thing to be easy and it is turning out to be the biggest PITA hahaha. When I build the 70 Chevelle I am going to spend some time in engineering school learning all of this, but until then I need somone to do the leg work and make some coin doing it. Thanks for all the input so far!
    Nov 2012
    I bought a OBD lan monitor to gather packet info.
    http://www.microchip.com/stellent/id...cName=en546534
    The goal is to build a plug in so that one doesn't lose driving functions when replacing the OEM radio in the CTS-V.
    Yes , GM screwed owners by making the radio part of the driving functions, HOW PHUCKING STUPID is that?
    What you want is something that generates the handshake, and verifies the vin #.
    Since it is a serial port, should be doable, but not easy.
    I know the radio repair guys that are real good have can bus generator software just so they can operate the radio on the bench.
    Something like this:
    http://www.saelig.com/EPW/EPE004.htm
    Jul 2013
    Yes that sounds about right. "You're DRUNK GM go home!" How not easy are we talking here, like 100s of hours of trial and error or just someone with the right motivation and a few weekends? I just found this, (http://www.alpine.com.au/showItem.php?item_id=246). I dont know if it is standalone and runs of its own information or if it plugs into the LAN and gathers information that way. I can only imagine that its the less applicable for me. I just sent an email to Alpine asking them direct. Any ideas?
  1. FB, Will it do what I want it to? newb question
    By amk136 in forum Fusion Brain
    Last Post: 08-05-2008, 12:58 AM
  2. Newb question
    By nigwhyrito in forum Wireless Communications
    Last Post: 02-29-2008, 11:23 AM
  3. newb LCD question
    By Lebult in forum Newbie
    Last Post: 02-07-2007, 01:13 PM
  4. Newb question about amp and sub
    By jon2341 in forum Car Audio
    Last Post: 10-29-2006, 10:03 AM
  5. Newb LCD question
    By TiziteLayinLow in forum LCD/Display
    Last Post: 03-04-2004, 06:28 PM
