Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Is This a Good Build?
  1. #11
    Newbie GamerGirlAlice's Avatar
    Jan 2013
    Broken Arrow, Oklahoma, United States
    what about the m4-atx 250w psu. what cases can i use the m4-atx 250w psu.
  2. #12
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Quote Originally Posted by bmw_car_pc View Post
    What are you using it for, I've never understood a big powerful system in a car when just using it for a simple front end program playing mp3's or gps.
    Ive got a dual core atom and running 1280 x 768 screen res its real laggy when switching screens in centrafuse...if i lower the screen res down its real sweet.but if i do that windows looks terible as i still use oziexplorer and a few other programs from within windows.i now regret buying a atom,as i will probably now buy another new setup.
    Buy the best you can afford
    Sent from my GT-N8020
  3. #13
    Jan 2013
    would it be hard to set up a nuc to power on and off with car?
    something like a Intel® NUC Kit D54250WYK powered by the CarNetix CNX-P2140 185W Dual Output Intelligent DC-DC Regulator?
  4. #14
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    The NUC is prolly 19v or 12v regulated power which you could get from either the carnetix 2140 or carnetix P1900 depending on which it is 12 or 19v. Both will give you your auto start and shut down. SNO
  5. #15
    Jan 2013
    trying to figure out if i can buy a second power brick for the new haswell nuc. has hd 5000 graphics, so be good for my mome tv and car. if i can find a second psu brick i could use on tv then when going out plug into car. im looking at a Intel® NUC Kit D54250WYK.
  6. #16
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I was seriously considering the NUC. It is 19V, so you will need to get an intellegent DC to DC converter for the car, and use the power brick at home. Great choice if you want to share as carpc, and home theater pc. Small, low power, quick and easy to connect. You could make it dual boot, with a boot menu for homepc mode or carpc mode and have it startup the front end software automatically. I think you have found the perfect pc for your application... due to be released this fall.
  7. #17
    Jan 2013
    how would i go about making a Intelligent DC-DC Converter with USB Interface power a nuc? reading the manuals, but never done anything this advance before for dual power.
  8. #18
    Jan 2013
    Last edit: since i have no idea how to custom wire a nuc computer i'm going to do a under dash carpc that plays audio threw radio. can u all tell me if i have a good set up
    • New Black BBX-1 Double Din Mini-ITX Carputer Enclosure With Front USB
    • Lilliput 7" SKD Open Frame Touch Screen VGA Monitor with HDMI, DVI Input
    • Intel Desktop Motherboard LGA1155 DDR3 1600 mini-ITX - BOXDH77DF
    • Intel Core i3-3245 3.40GHz 2 LGA 1155 Processor BX80637I33245
    • Crucial Ballistix Sport Very Low Profile 8GB Kit (4GBx2) DDR3-1600 1.35V UDIMM 240-Pin Memory Modules Crucial M500 240GB mSATA Internal Solid State Drive CT240M500SSD3
    • M3-ATX, 125w output, 6v to 24v wide input Robust and Intelligent Automotive DC-DC Car PC Power Supply
    • iSimple IS31 Antenna Bypass FM Modulator for Factory or Aftermarket Car Radios
    • iSimple IS335 Dash Mountable Auxiliary Input Adapter
    • HDMI Right Angle HDMI Adapter
    • Metra 95-9000 Universal Double DIN Housing Installation Dash Kit
  9. #19
    Jan 2013
    i been doing lots reserch for low power cpus to do a small but fast media/email/centerfuse build. the low sized ram is for airflow with its ultra low profile.
    Can You Tell me if the research i did will make a simple fast media/email/centrafuse carpc?
    • Gigabyte LGA 1150 Intel Z87 HDMI SATA 6Gbps USB 3.0 Mini ITX DDR3 1600 Intel Motherboards GA-Z87N-WIFI
    • Intel I3-4340 3.6 3 LGA 1155 Processor BX80646I34340
    • Crucial Ballistix Sport Very Low Profile 8GB Kit (4GBx2) DDR3-1600 1.35V UDIMM 240-Pin Memory Modules BLS2C4G3D1609E​S2LX0
    • Crucial M500 240GB SATA 2.5-Inch 7mm (with 9.5mm adapter) Internal Solid State Drive CT240M500SSD1
  1. Are there any good pre-build double din carputers?
    By PlayWithFire in forum Newbie
    Last Post: 07-16-2010, 07:49 AM
  2. Is this integrated FM/AM tuner-on-a-chip any good? Should I build one?
    By xraycat in forum General Hardware Discussion
    Last Post: 01-21-2007, 04:05 AM
  3. Replies: 0
    Last Post: 01-19-2007, 02:58 PM
  4. Replies: 7
    Last Post: 12-05-2004, 09:13 PM
