Results 1 to 6 of 6
Thread: line drivers
    Jan 2008
    Wellsboro, Pennsylvania, United States
    line drivers
    Any one ever use one of these ? - http://www.crutchfield.com/g_331950/....html?tp=61662
    From my understanding it can help boost the RCA's signal. Not sure if its messing with on my system or not yet.
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    I haven't used one but I'm leaning towards it. But I seen cheaper.
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    it really depends on what you're components are in your system. we'd need more information. I've used audiocontrol before; an active x-over + line driver and it made a nice improvement over my first system. but we need to know more about your setup
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jan 2008
    Right now I am just using an MP3 player...to a 4x100 rms Kenwood Amp...that then goes to a Rockford mono 1000RMS via the passthru...when I get my computer in...not sure what that set up will be...need to get my monitor first
    Elsewhere
    I can't speak to any of AudioControl's line drivers.
    I currently run an AudioControl Three.1 equalizer (no longer in production, replaced by the Three.2) in my system for a few specific benefits:
    • A physical volume control.
      If my PC ever locks up with some horrific sound coming from the speakers, I can turn it down and save my eardrums. Also, if passengers ant to turn down the music, they're going to look for a volume knob. In my truck, they'll find one.
    • Increased audio output voltage.
      Output voltage is increased to nearly 3v, making my amps happy. If the amps are happy, the ears are happy.
    • Simple left/right stereo output from the PC means no issues with audio sources that don't support 4.1, 5.1 or other surround layouts.
      A higher voltage audio signal is less susceptible to RFI, so fewer cables with the lower voltage audio signal means less chance of RFI inducing noise into the system.
    How about the Wiki?
    Nov 2004
    St Louis
    Quote Originally Posted by scott_fx View Post
    +1
    Depending on your system setup, cheaper, less complicated options are available.
  1. Question about line levels, line drivers and/or EQ's
    By malcom2073 in forum Car Audio
    Last Post: 09-01-2009, 02:01 AM
  2. Replies: 12
    Last Post: 10-15-2006, 09:59 PM
  3. Speaker Popping Noise (delay circuit options?), Line Drivers to boost volume which 1?
    By SuprchargdMazda in forum General Hardware Discussion
    Last Post: 05-26-2006, 08:57 PM
  4. Line drivers pre-amps
    By sirope in forum Car Audio
    Last Post: 09-19-2004, 08:13 PM
  5. rs-232 line drivers
    By marsjell in forum General Hardware Discussion
    Last Post: 07-25-2001, 05:32 PM
