Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Network usb server?
  1. #11
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Would it then be possible to share that touch screen with another network attached device...say share touch screen with carpc and a odroid?obviously not both at the same time?
  2. #12
    Jun 2011
    Atlanta
    Do not know on that one camo.b.. I am not sharing with what I am doing. I guess you could. The devices will access the network through the router on what I am doing. Not sure what you are tiring to do.
  3. #13
    Nov 2011
    At one point I was thinking running a odriod for obd torque / mapping and a carpc to the same screen via hdmi and vga.....hoping to switch the touch between the two...depending on what was running...still thinking about it
  4. #14
    Jun 2011
    Atlanta
    I see. You could do something like that by channel switching. Switching from one feed source to another source. Or you could use the CarPc as the main source and feed the odroid as a feed through the network shared. Then access it from the main in the one screen. If you want to use the touch feature on a screen to access it.
    In the screen I am using. It has different channels on the board you can select. Via a Usb buttons. So I could select Av1 by trigger wire on reverse camera or manual selection. Av2, Vga, and Hdmi channels by Usb buttons. It auto switches also back to the last channel selected. When you trigger the Av1 by trigger wire. And that is not even using the touch feature of the screen.
  5. #15
    Jun 2011
    Atlanta
    To give a little insight on where I am fitting and what I am working with. Here are some pictures.
    This is the screen.
    Name:  housing front.jpg
    This is the housing.
    I am trying to simplify connections to the housing. I am going to use the factory connectors as few others as I can. To make it easy to put in and remove. Basically plug the housing into a harness in the car and if necessary be able to quickly remove by the mounting screws and as few connectors as possible to pull it out.
    Here is the two factory plugs I will re purpose.
  6. #16
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Well, you can certainly fit some of the small powered USB hubs in there, and I did find a small USB over ethernet 4 port powered hub on ebay that would fit however it's a USB device not an ethernet device:
    http://www.ebay.com/itm/151081430537
    This USB over IP Hub is economical, however it's larger and probably a tight fit:
    http://www.ebay.com/itm/200860721708
  7. #17
    Jun 2011
    Atlanta
    rray thanks the SEDNA might fit the bill. I will do that one or just end up doing a usb hub and usb repeater cable.
  1. connect to a network server
    By govee in forum LinuxICE
    Last Post: 12-27-2009, 09:10 AM
  2. SEVERE NETWORK OUTAGE(Network Solutions)
    By legacy05gt in forum Off Topic
    Last Post: 10-17-2006, 02:02 PM
  3. Watching Machine - Shutdown server when CarPC out of Network Range.
    By WhoIsThisGuy? in forum Software & Software Development
    Last Post: 11-24-2005, 01:26 PM
  4. USB Server Over A Network ?
    By ccsnet in forum Off Topic
    Last Post: 10-20-2004, 01:05 AM
  5. mp3 Web Server App
    By chainsaw76 in forum Software & Software Development
    Last Post: 12-06-2000, 11:32 AM
