Results 1 to 10 of 17
Thread: Network usb server?
    Jun 2011
    Atlanta
    Network usb server?
    Does anyone have any good ideas on a super compact 4 usb port to (Lan) server. I want run a wired network to touchscreen and some usb buttons.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i used a belkin usb/lan port
    Belkin F5L009 5-Port Network USB Hub
    i had it hooked up to a dac and it work well
    http://youtu.be/CUr1leHiZ58
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jun 2011
    Atlanta
    Wired not wireless and super compact.
    Dec 2004
    Los Angeles Ca
    it is wired. i added a router to make it wireless. don't know what your definition of super compact is though... it is slim
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    The Ram mount hub has built-in ethernet, http://www.rammount.com/NewProducts/...6/Default.aspx it's about 4"x4" in it's box but much smaller insides. Just a thought SNO
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    What is that Ethernet port on the ram USB hub for exactly. Its not in any of their documentation?
    -Robert
    Nov 2009
    Keswick,On Canada
    Hope this helps
    The Ethernet port on the RAM-234-HUB1 can be used for sharing Ethernet data from network devices via USB. You can connect Ethernet based devices like IP cameras, communications equipment ... You can quickly disconnect all peripherals with one USB connection and vice versa which makes taking the laptop in and out of your vehicle quick and easy. The drivers should auto install for using that feature.
    info is really vague on this addon SNO
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Does that mean if you connect only the ethernet cable to your car pc, and the hub is powered by the car's 12v, and you plug in a thumb drive, you have network attached storage?
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Or does it mean it converts an IP camera into a USB webcam?
    Jun 2011
    Atlanta
    rray Yes that is the idea. You can have network storage and network available devices.
    My thing is I need 4usbs to network. To take touch screen usb and some others and drive them across the network.
    It is for the same touchscreen you use. I am putting it in a motorized housing in my IS300. To replace the factory Nav screen with the interface for my CarPc.
    That is why I am looking for one that is super compact.
  1. connect to a network server
    By govee in forum LinuxICE
    Last Post: 12-27-2009, 09:10 AM
  2. SEVERE NETWORK OUTAGE(Network Solutions)
    By legacy05gt in forum Off Topic
    Last Post: 10-17-2006, 02:02 PM
  3. Watching Machine - Shutdown server when CarPC out of Network Range.
    By WhoIsThisGuy? in forum Software & Software Development
    Last Post: 11-24-2005, 01:26 PM
  4. USB Server Over A Network ?
    By ccsnet in forum Off Topic
    Last Post: 10-20-2004, 01:05 AM
  5. mp3 Web Server App
    By chainsaw76 in forum Software & Software Development
    Last Post: 12-06-2000, 11:32 AM
