Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: First ever Car PC attempt
  1. #11
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I took pictures of the audio install and wiring, but I am waiting for Puneet to post the new thread.
    We have been working on it 4 weeks now, and last weekend we worked on the bezel to fit the Dell Venue Pro about 1" behind the dash opening to fit the uUSB plug.
    -Robert
  2. #12
    Aug 2006
    Colorado
    Quote Originally Posted by rray View Post
    -Robert
    Sweet! Hit me up when you do. I'd love to see how it turned out. How did wire up the audio, USB DAC? What car did you install into?
  3. #13
    Constant Bitrate Project07MACry's Avatar
    Aug 2009
    BK, NY
    Hey there, “old lady!” Welcome to MP3Car!
    Since you already got some equipment, I take it you want to use that and go forward. The ASUS machine you purchased should get the job done; you just need some extra accessories.
    • For the auto diagnostics, your car does use the OBD-I scanner. Check out this unit for starters, and do check out a good Serial-USB converter (yeah, there should be one Amazon recommends on the same page); you will need it to connect the reader to the computer. Software is included with it, but you may find better solutions on the internet.
    • Music & movies should not be a problem, as long as you allocate the right amount of space for it. As @Happy_Feet suggested, a front-end software (Centrafuse, for example) would be ideal if you want to run your CarPC like a car. It is not necessary, but it would save you from any unnecessary clicks.
    • Does your phone do tethering (internet sharing)? Because you will need some sort of mobile hotspot (or free wifi) to access the internet in your CarPC.
    • GPS – I use the earlier version to this model and it works fine. But this adapter is highly recommended. As far as software is concerned, there are options; and @SNOtwistR can give you his recommendation(s).
    • As far as connecting it to the car, @DarquePervert’s suggestion of an inverter may be best for your car/computer.
    Before I go, there are some questions you might want to consider:
    1. What operating system (OS) are you using? The Windows 7 that the computer came with? Because Linux and Windows 8 might be better options.
    2. What speakers/audio setup do you have? If you have stock speakers and like it, then that’s cool. If you have stock and it’s getting old, then that’s something else to consider. Or maybe you have upgraded speakers already…
    2a. Is your system including amplifiers and subwoofers? Because you have to connect the speakers to your computer, and you might as well make sure it sounds very good.
    3. Now that the thread has thrown the tablet-PC idea at you, is that something you want to consider? There are models out there with GPS/Wifi built-in, so there is not much accessories to buy.
    4. THE MOST IMPORTANT (to me anyways) –Are you fabricating any part of this CarPC? Are you just mounting the PC and screen in certain parts of the car? Do you want to make it look like the whole thing is part of the car? Will you/Do-you-know-someone-who-will help put this all together? Once you know that for sure, you are on your way.
    Best of luck to you!
    All systems are a go...
    Currently in "tweaking" mode.
    The Worklog
  1. My first cap pc attempt
    By ice203 in forum Newbie
    Last Post: 11-17-2009, 06:50 PM
  2. MY first attempt at fab *WIP*
    By FyreDaug in forum Fabrication
    Last Post: 11-27-2006, 02:26 AM
  3. First Attempt
    By maiwand in forum RR Skins
    Last Post: 11-29-2005, 02:52 PM
  4. First attempt...
    By markbuts3 in forum RR Skins
    Last Post: 07-21-2005, 11:37 AM
  5. First Attempt...
    By RoyN in forum RR Skins
    Last Post: 04-07-2005, 11:24 AM
Tags for this Thread
