Results 1 to 2 of 2
Thread: Small project need direction
    May 2014
    First off, im absolutely amazed by some of the projects on here and how in depth the whole electronic modding thing can go.
    So here's what i've got going on...
    I have a Nissan 240sx with a consult cable, I'm using an ECUTalk USB adapter in order to display ECU information on my windows 7 laptop through their program. Here's a link if you need more specific info: http://www.ecutalk.com/ecutalk.aspx
    So basically I need some device or setup that can take data from a usb input, run an exe file to read that data and display it on a small screen.
    I'm thinking that a full car PC would be overkill but its too complicated (based on my current knowledge) to run the exe file on an android setup.
    Ideally I would have a small (5"-7") touchscreen that I could tuck in the glovebox when not in use, or even disconnect to remove it when needed.
    Right now im looking at tablets, netbooks, car PC's, and the pocket PC option but I'm hoping someone could clarify or give me a more clear direction for my research.
    Thanks!
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Welcome to the forum! I think for what you want to do you will need a PC. A good 7" high brightness/5 wire touch will be fine. A nice little i3-i5-i7 mini-itx with ssd will run your app as well as anything else you might want to run. A front-end software will make life much easier in the car, my recommendation on that would be Driveline for ease of installation and setup. Sticking with windows pc, you will have little trouble getting it upand running. Good luck and make a worklog once you get going SNO
  1. New project looking for some direction
    By toazron1 in forum Newbie
    Last Post: 08-09-2013, 03:01 PM
  2. Replies: 1
    Last Post: 12-27-2008, 03:27 PM
  3. Small project
    By rgarjr in forum Fabrication
    Last Post: 02-12-2008, 11:43 PM
  4. 04 350z Convertible "small time project".
    By kermityfrog in forum Show off your project
    Last Post: 02-17-2007, 07:30 PM
  5. new project, small car
    By potschi in forum General MP3Car Discussion
    Last Post: 04-09-2003, 09:34 AM
