Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: Mini itx carputer
  1. #11
    Jul 2012
    Thanks mate ill have a look into that. This is the board i am using UM_EPIA-TC_121 The instructions are located here
    http://www.viaembedded.com/en/produc...ard_(EOL).html
    I cant seem to find another pin on the board that could be used to make the board hibernate :-( any ideas?
    May 2012
    Grandville, MI
    Normally you can assign what you want the power button to do. Shut down, hibernate, sleep etc.
  3. #13
    Jul 2012
    Thanks mste is that done via windows software? There's nothing in bios. Only thing I can see the switch does is off on 1 press or off after pressing for 4 secs :-(
  4. #14
    May 2012
    Grandville, MI
    Yes under windows....
    Control Panel > Power Options > "Choose what power button does"
    Rodney
  5. #15
    May 2012
    Grandville, MI
    Ride Runner is Free now... I seem to recall it was pay for a while or atleast required a registration or something but I see it is now fully free. Maybe it was shareware? Not sure...
    Anyhow doesn't matter, just looked and it is definitely free now.
  6. #16
    Jul 2012
    Muchas Gracias. Finally managed to get win 98 to load so now time to upgrade to vista.
  7. #17
    May 2012
    Grandville, MI
    Don't do Vista....Vista is crap...
    Rodney
  8. #18
    Jul 2012
    ive ordered 7 now mate :0 just hoping by board will run it ok...
  9. #19
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I am not sure that board will run with win7, it's very old and might not have any drivers I think your best bet is XP and then use the pos hack on it to continue getting updates. from the looks of the specs I'd say circa 2003-2005 era. Good luck SNO
  10. #20
    May 2012
    Grandville, MI
    Only way to know if it will work with Win7 is to try it. If it was setup to run Vista chances are it will run on Win 7 without issue.
    Just be aware that Win 7 32 bit is more compatible with the older operating systems than 64 bit.
    Beyond all of that you can always update your board depending on your location. You can get a fully populated board for cheap these days that has everything you need to run Win 7 or Win 8.
    Rodney
  1. carputer in a Mini?
    By Huff in forum General MP3Car Discussion
    Last Post: 07-13-2007, 02:40 PM
  2. Replies: 12
    Last Post: 01-16-2007, 01:42 PM
  3. Carputer car PC Mini-ITX
    By swerv in forum Classified Archive
    Last Post: 12-07-2006, 12:28 PM
  4. FS: MP-SC8 Mini PC Carputer
    By koolharshis in forum Classified Archive
    Last Post: 08-05-2006, 07:18 PM
