Results 1 to 4 of 4
Thread: CarPC wont start after hibernation
    Jun 2008
    Yesterday, I installed the PC from my old car into the replacement. All went well and it fired up and functioned properly first time. When I stopped and turned the car off for the first time, I thought I'd check the system again. I waited till the PC shutdown then restarted the car. NOTHING!!! The only way I could get it started was to remove the fuse then replace it back in the fusebox. Started straight away then. Any solutions beside hard wiring it without a fuse?
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Sounds like you haven't picked up the right wire for the acc circuit on the car.
    Sent from my iPhone using Tapatalk
    Jun 2008
    I'm certain the 12 volt accessories wire is sourced correctly. It is a constant 12v when the key is at accessories. Could this possibly be anything to do with the onboard battery. I notice it doesn't keep time/date so must be flat. The fuse I'm having to remove/replace is on the constant power line.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    You technically want ignition wire not just accessory. Accessory usually cuts out when in start position. I would also replace that on-board battery (mainboard we are talking about) not that would have any bearing on your original problem. Good luck SNO
  1. Screen wont work after hibernation
    By amk136 in forum General Hardware Discussion
    Last Post: 12-10-2008, 11:49 PM
  2. navigtion still wont start up
    By mrcgibb in forum CF Bug Reports
    Last Post: 08-07-2008, 09:50 AM
  3. Configure setting wont take/RR wont start
    By pickuptrck in forum Road Runner
    Last Post: 06-05-2008, 04:26 PM
  4. RR wont start
    By lez in forum Road Runner
    Last Post: 09-30-2007, 04:30 AM
  5. MII 1200 wont start up
    By tibman260 in forum General MP3Car Discussion
    Last Post: 01-09-2006, 02:27 PM
